Sensor
Kathleen Hamilton
更新时间 2024-09-11 19:43:50 UTC
浏览: 1746   回复: 1
Thomas Murphy
更新时间 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
浏览: 1646   回复: 1
Zone 1 not watering
11807GFT
更新时间 2024-09-24 23:25:59 UTC
浏览: 1609   回复: 1
Schedules
jonathansalina
更新时间 2024-09-28 11:11:52 UTC
浏览: 1582   回复: 1
How do I?
Rockhead413
更新时间 2024-10-01 00:08:51 UTC
Vincent Devlahovich
805-813-1216
Loyal customer
浏览: 1514   回复: 1
1 zone not watering
cowlo@xtra.co.nz
更新时间 2024-10-01 01:41:13 UTC
浏览: 1681   回复: 1
Manual mode without delay
Phil Houghton
更新时间 2024-10-04 23:27:59 UTC
浏览: 1440   回复: 1
cjulian
更新时间 2024-10-05 18:05:09 UTC
浏览: 1466   回复: 1
Set up weather underground
Giovannini Alex
更新时间 2024-10-05 18:35:32 UTC
Alex
浏览: 1607   回复: 1
Water restriction schedule problem
Carolyn Simmons
更新时间 2024-10-08 00:12:28 UTC
I cannot get the system to set up our county water restriction schedule. It is Wed and Saturday up to 10am in morning and after 6 pm at night. I would really like to run each zone once in the morning and once at night!  Any suggestions before I get fined $200.00?
浏览: 1543   回复: 1
12330barryknoll
更新时间 2024-10-10 01:51:03 UTC
浏览: 1483   回复: 1
BrettEnyart
更新时间 2024-10-13 18:02:06 UTC
浏览: 1480   回复: 1
Conrtoler
John Zuzula
更新时间 2024-10-19 23:45:24 UTC
浏览: 1411   回复: 1
Zine will not run
TJ Woods
更新时间 2024-10-27 14:40:45 UTC
浏览: 1584   回复: 1
Zone won't shut off.
shoo.shoo
更新时间 2024-11-10 05:55:43 UTC
浏览: 1300   回复: 1
Konrad
berlin
更新时间 2024-11-10 09:36:28 UTC
Who can help me?
Thank's
Konrad
浏览: 1311   回复: 1
Netro Spark valve testing
Peter Strohmayer
更新时间 2024-11-14 13:49:20 UTC
Peter
浏览: 1257   回复: 1
Solenoid does not switch off
Nath Moyes
更新时间 2024-11-15 00:49:20 UTC
Nath
浏览: 1331   回复: 1
Andrea DS
更新时间 2024-11-27 21:01:38 UTC
浏览: 1210   回复: 1
Carolyn Simmons
更新时间 2024-12-01 20:53:00 UTC
浏览: 1197   回复: 1
