Whisperer 2 Dead
更新时间 2025-05-27 23:06:05
浏览: 130   回复: 1
How do I change schedule
George S
更新时间 2025-05-27 21:37:14
浏览: 105   回复: 1
New Sprite Owner
Bryant Bustamante
更新时间 2025-05-26 22:46:01
浏览: 157   回复: 1
Mikael Hammarin
更新时间 2025-05-26 17:18:52
Suggestion:
浏览: 138   回复: 1
Battery Issue - Netro Stream
K L
更新时间 2025-05-25 03:09:56
Dear Fellows,
Device Details:
  • Hardware : Netro Stream 1.0
  • Firmware: 1.0.0
Best regards,
Kelvin
浏览: 160   回复: 1
Refurbished netro controller
drylake
更新时间 2025-05-23 23:37:47
浏览: 160   回复: 1
overwatering
更新时间 2025-05-20 12:55:43
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
浏览: 324   回复: 2
Pierluigi Cilli
更新时间 2024-09-08 07:29:59
浏览: 1897   回复: 1
cjulian
更新时间 2024-10-05 18:05:09
浏览: 1622   回复: 1
Manual mode without delay
Phil Houghton
更新时间 2024-10-04 23:27:59
浏览: 1585   回复: 1
1 zone not watering
cowlo@xtra.co.nz
更新时间 2024-10-01 01:41:13
浏览: 1846   回复: 1
How do I?
Rockhead413
更新时间 2024-10-01 00:08:51
Vincent Devlahovich
805-813-1216
Loyal customer
浏览: 1659   回复: 1
Schedules
jonathansalina
更新时间 2024-09-28 11:11:52
浏览: 1743   回复: 1
Zone 1 not watering
11807GFT
更新时间 2024-09-24 23:25:59
浏览: 1769   回复: 1
Broken whisperer sensor
Jesús López
更新时间 2024-09-09 16:19:33
Hi everyone!
浏览: 1973   回复: 2
Tie the irrigation of two lines on the same garden
Francesco
更新时间 2024-09-04 07:59:17
I have two irrigation lines on the same garden, is there any setting that would allow these two areas to be “tied together” such that they irrigate on the same day (session)? (Obviously first one line and then the other).
浏览: 1903   回复: 1
Discrepancia APP y WEB
JM del Amo
更新时间 2024-09-07 13:06:53
浏览: 1915   回复: 1
Conrtoler
John Zuzula
更新时间 2024-10-19 23:45:24
浏览: 1553   回复: 1
Thomas Murphy
更新时间 2024-09-18 12:39:46
Hello there!
Thank you so much!
浏览: 1808   回复: 1
Smart watering not working
更新时间 2024-09-10 16:17:51
浏览: 1893   回复: 1
