Minh Thu Nguyen
更新时间 2025-05-19 08:42:52 UTC
Dear Netro Support Team,
Best regards,
Minh Thu, Nguyen
浏览: 1859   回复: 1
Smart Zones are random
Dave H
更新时间 2025-05-19 15:27:46 UTC
Sprite-12
and/or
浏览: 1755   回复: 1
overwatering
更新时间 2025-05-20 12:55:43 UTC
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
浏览: 1760   回复: 2
Refurbished netro controller
drylake
更新时间 2025-05-23 23:37:47 UTC
浏览: 1531   回复: 1
Battery Issue - Netro Stream
K L
更新时间 2025-05-25 03:09:56 UTC
Dear Fellows,
Device Details:
  • Hardware : Netro Stream 1.0
  • Firmware: 1.0.0
Best regards,
Kelvin
浏览: 1762   回复: 1
Mikael Hammarin
更新时间 2025-05-26 17:18:52 UTC
Suggestion:
浏览: 1742   回复: 1
New Sprite Owner
Bryant Bustamante
更新时间 2025-05-26 22:46:01 UTC
浏览: 1778   回复: 1
How do I change schedule
George S
更新时间 2025-05-27 21:37:14 UTC
浏览: 1644   回复: 1
Whisperer 2 Dead
更新时间 2025-05-27 23:06:05 UTC
浏览: 1787   回复: 2
Water consumption
cwo
更新时间 2025-06-01 19:51:34 UTC
浏览: 1557   回复: 1
Angelo Suppa
更新时间 2025-06-11 16:54:13 UTC
浏览: 1103   回复: 2
更新时间 2025-06-25 16:41:56 UTC
浏览: 618   回复: 1
Pierluigi Erba
更新时间 2025-06-25 14:39:59 UTC
My account Pier1972
浏览: 718   回复: 0
Umidità terreno
Alessandro Zannini
更新时间 2025-07-03 19:20:15 UTC
浏览: 1408   回复: 1
Time range not respected
Fabio Silvestri
更新时间 2025-06-19 16:29:56 UTC
浏览: 696   回复: 1
Plant needs
Bob Benny
更新时间 2025-06-19 00:30:05 UTC
Thank you for your help.
浏览: 774   回复: 1
更新时间 2025-06-18 03:59:06 UTC
浏览: 795   回复: 1
francescomaggi
更新时间 2025-06-16 21:04:10 UTC
浏览: 746   回复: 3
Lorenzo Bigagli
更新时间 2025-06-14 12:02:48 UTC
Please
浏览: 885   回复: 1
Contrôler problem
Alain Turcotte
更新时间 2025-06-06 09:41:00 UTC
浏览: 1349   回复: 2
