Valve compatible with Netro
Francesco Manella
更新时间 2025-06-29 10:55:38 UTC
Hi everyone,
Thanks to every can help me
浏览: 733   回复: 0
Unified controllers
Gianluca Spada
更新时间 2025-06-29 20:59:51 UTC
浏览: 802   回复: 1
Valve not opening
更新时间 2025-07-01 05:11:54 UTC
I have a Netto controller 12
浏览: 715   回复: 1
Wifi error
nvenezia
更新时间 2025-07-02 14:51:10 UTC
浏览: 952   回复: 2
Veronica Slaughter
更新时间 2025-07-03 12:43:45 UTC
浏览: 1100   回复: 0
Whisperer 1 Dead
更新时间 2025-07-03 15:13:13 UTC
浏览: 1085   回复: 0
Gyade B.
更新时间 2025-07-03 23:32:35 UTC
浏览: 1125   回复: 1
Sensors missing
dano
更新时间 2025-07-06 00:06:15 UTC
Dan
浏览: 1079   回复: 1
WEATHER CONDITIONS - Rain
Zsolt Karman
更新时间 2025-07-08 10:23:15 UTC
Hi Team,
Could you please ?
Controller SN: 0cb815314670
Regards, Zsolt
浏览: 1067   回复: 1
Spark 8 zones
Jesus Laso
更新时间 2025-07-10 13:05:31 UTC
Good afternoon,
Thais in advance
浏览: 1043   回复: 1
更新时间 2025-07-10 18:58:03 UTC
Kirk
浏览: 988   回复: 1
Ricardo Ribeiro
更新时间 2025-07-12 13:05:48 UTC
Can you help?
浏览: 978   回复: 1
nsutherland
更新时间 2025-07-14 01:33:11 UTC
浏览: 990   回复: 1
Daniele Fuccio
更新时间 2025-07-18 17:17:18 UTC
What could the issue be?
Thank you in advance
浏览: 966   回复: 1
Whisper not showing any moisture reading at all
更新时间 2025-08-12 02:45:00 UTC
Why is Whisperer not showing any moisture reading at all? after working fine for days, it just stops sending moisture info
浏览: 330   回复: 1
App reports off-line, controller is on-line and web based app is on-line
Jorge Rodrigues
更新时间 2025-08-08 18:46:45 UTC
I have a strange situation:
- App reports controller as off-line, sometimes it reports on-line for brief periods. It was working fine till three days ago
- Controller has green light
- Web app on the netro site reports on-line and works
- The controller is watering
- The Wifi near the controller is working and I have not changed the password or settings
- I have tried forcing it to change the wifi, I get the bluetooth light and the controller is detected on the app via bluetooth, however it fails after I insert the password for the wifi. This is odd since the device is connected.
I suspect there is a synch issue between the App and your servers. Help would be appreciated.
浏览: 273   回复: 1
更新时间 2025-08-10 00:01:57 UTC
浏览: 260   回复: 1
Problem: Spark 8 controller stuck on "in communication"
Stefano F
更新时间 2025-08-10 07:01:41 UTC
Hi everyone,
I'm experiencing a serious issue with my Netro Spark 8 controller. It connects correctly to Wi-Fi and appears online in the app, but when I try to start irrigation manually, the app just stays on "in communication" and nothing happens.
Despite these attempts, the problem persists. I also tested the solenoids with a multimeter, and they’re working correctly. If I activate the valves directly from the controller, they respond as expected—so it’s clearly not a hardware issue.
I should also mention that I previously had the same problem with two Sprite6 controllers. That’s why I switched to the Spark 8, hoping it would solve the issue. Unfortunately, it hasn’t.
To make matters worse, scheduled programs aren’t working either.
This is an urgent situation because my plants are currently without water. I’d really appreciate any help or suggestions to resolve this.
Thanks in advance,
Stefano
浏览: 313   回复: 2
Spark 16 works only in manual
Davide Riva
更新时间 2025-08-11 21:55:04 UTC
Hello, I’ve installed netro app on my iPhone, followed the procedure to connect the spark 16 and everything is fine, but when I try to activate valves with the app, the led turn white.
If I remove spark 16 from the app, the led turn green and I can only activate valves from the controller,
Any solution?
Davide
浏览: 364   回复: 2
Remote reboot of whisperer
更新时间 2025-08-17 14:48:38 UTC
Is there a way to remotely reboot a whisperer sensor?
I am on vacation adn one of the sensors is showing up weird values in all the parameters.
浏览: 295   回复: 1
