Zine will not run
TJ Woods
更新时间 2024-10-27 14:40:45 UTC
浏览: 3079   回复: 1
Discrepancia APP y WEB
JM del Amo
更新时间 2024-09-07 13:06:53 UTC
浏览: 3080   回复: 1
Pierluigi Cilli
更新时间 2024-09-08 07:29:59 UTC
浏览: 3176   回复: 1
Broken whisperer sensor
Jesús López
更新时间 2024-09-09 16:19:33 UTC
Hi everyone!
浏览: 3270   回复: 2
Smart watering not working
更新时间 2024-09-10 16:17:51 UTC
浏览: 3075   回复: 1
Sensor
Kathleen Hamilton
更新时间 2024-09-11 19:43:50 UTC
浏览: 3134   回复: 1
Thomas Murphy
更新时间 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
浏览: 3022   回复: 1
Zone 1 not watering
11807GFT
更新时间 2024-09-24 23:25:59 UTC
浏览: 3024   回复: 1
Schedules
jonathansalina
更新时间 2024-09-28 11:11:52 UTC
浏览: 2936   回复: 1
How do I?
Rockhead413
更新时间 2024-10-01 00:08:51 UTC
Vincent Devlahovich
805-813-1216
Loyal customer
浏览: 2853   回复: 1
1 zone not watering
cowlo@xtra.co.nz
更新时间 2024-10-01 01:41:13 UTC
浏览: 3145   回复: 1
Manual mode without delay
Phil Houghton
更新时间 2024-10-04 23:27:59 UTC
浏览: 2782   回复: 1
cjulian
更新时间 2024-10-05 18:05:09 UTC
浏览: 2944   回复: 1
Set up weather underground
Giovannini Alex
更新时间 2024-10-05 18:35:32 UTC
Alex
浏览: 3013   回复: 1
Water restriction schedule problem
Carolyn Simmons
更新时间 2024-10-08 00:12:28 UTC
I cannot get the system to set up our county water restriction schedule. It is Wed and Saturday up to 10am in morning and after 6 pm at night. I would really like to run each zone once in the morning and once at night!  Any suggestions before I get fined $200.00?
浏览: 3149   回复: 1
12330barryknoll
更新时间 2024-10-10 01:51:03 UTC
浏览: 2933   回复: 1
BrettEnyart
更新时间 2024-10-13 18:02:06 UTC
浏览: 2927   回复: 1
Conrtoler
John Zuzula
更新时间 2024-10-19 23:45:24 UTC
浏览: 2748   回复: 1
Reset, but still not connecting
lorenzo s
更新时间 2024-12-19 23:36:08 UTC
Please help. I'll provide a reward for getting my N-12 to work.
lss
浏览: 3275   回复: 1
John BAIMAY
更新时间 2024-12-26 11:35:25 UTC
Regards.
浏览: 2511   回复: 1
