Mike Carey
更新时间 2026-09-04 14:18:00 UTC
浏览: 163   回复: 2
Smart watering isn’t working
Weikang Chen
更新时间 2026-08-21 00:17:31 UTC
I have 2 problems with the Netro this year.
1. The weather auto detect to rain to skip the water session doesn’t work.   No matter how low the threshold I set to, it doesn’t skip the water day when it rains.  I have it set to .1 inch now.
2. When I set to delay the watering , it doesn’t reschedule the schedule.   It just continue with the watering.
My system has been watering while it’s pouring outside so many times and wasted so much money on my water bill because this app screwed up so bad.
Is there a the fix to my problems?
浏览: 416   回复: 1
nsutherland
更新时间 2025-07-14 01:33:11 UTC
浏览: 4124   回复: 1
更新时间 2025-06-16 21:04:10 UTC
浏览: 6559   回复: 3
Ricardo Ribeiro
更新时间 2025-07-12 13:05:48 UTC
Can you help?
浏览: 4480   回复: 1
更新时间 2025-07-10 18:58:03 UTC
Kirk
浏览: 4508   回复: 1
Spark 8 zones
Jesus Laso
更新时间 2025-07-10 13:05:31 UTC
Good afternoon,
Thais in advance
浏览: 6753   回复: 1
WEATHER CONDITIONS - Rain
Zsolt Karman
更新时间 2025-07-08 10:23:15 UTC
Hi Team,
Could you please ?
Controller SN: 0cb815314670
Regards, Zsolt
浏览: 6841   回复: 1
Sensors missing
dano
更新时间 2025-07-06 00:06:15 UTC
Dan
浏览: 6726   回复: 1
Gyade B.
更新时间 2025-07-03 23:32:35 UTC
浏览: 6678   回复: 1
Whisperer 1 Dead
更新时间 2025-07-03 15:13:13 UTC
浏览: 6844   回复: 0
Veronica Slaughter
更新时间 2025-07-03 12:43:45 UTC
浏览: 6454   回复: 0
Wifi error
nvenezia
更新时间 2025-07-02 14:51:10 UTC
浏览: 6673   回复: 2
Valve not opening
更新时间 2025-07-01 05:11:54 UTC
I have a Netto controller 12
浏览: 6118   回复: 1
Unified controllers
Gianluca Spada
更新时间 2025-06-29 20:59:51 UTC
浏览: 6413   回复: 1
Plant needs
Bob Benny
更新时间 2025-06-19 00:30:05 UTC
Thank you for your help.
浏览: 5613   回复: 1
Umidità terreno
Alessandro Zannini
更新时间 2025-07-03 19:20:15 UTC
浏览: 7038   回复: 1
Time range not respected
Fabio Silvestri
更新时间 2025-06-19 16:29:56 UTC
浏览: 6191   回复: 1
Pierluigi Erba
更新时间 2025-06-25 14:39:59 UTC
My account Pier1972
浏览: 6134   回复: 0
更新时间 2025-06-18 03:59:06 UTC
浏览: 5925   回复: 1
