Garden Bib
Grant Sullivan
更新时间 2025-04-22 22:01:02 UTC
浏览: 1924   回复: 1
Whisperer 2
Stephen Brewer
更新时间 2025-04-24 13:43:01 UTC
Steve
浏览: 1735   回复: 1
Server Down 4/27/25?
更新时间 2025-04-27 19:38:18 UTC
浏览: 1825   回复: 5
Irrigation system service
Rick Joseph
更新时间 2025-04-27 19:53:45 UTC
浏览: 1586   回复: 0
does not irrigate
Giovanni Asoni
更新时间 2025-04-28 15:58:30 UTC
浏览: 1818   回复: 1
IFTTT Trigger for moisture
Kareo
更新时间 2025-04-29 04:50:52 UTC
浏览: 1845   回复: 2
Soil and weather
Stephen Brewer
更新时间 2025-04-29 10:06:27 UTC
Steve
浏览: 1980   回复: 1
Batteria pixie
Max64
更新时间 2025-05-02 08:32:19 UTC
浏览: 1716   回复: 1
Pixie Offline
mprtjd
更新时间 2025-05-03 15:33:15 UTC
浏览: 1776   回复: 1
How to create a 2nd user
bdelariva
更新时间 2025-05-04 13:16:18 UTC
浏览: 1916   回复: 1
Kai Nicholson
更新时间 2025-05-04 14:12:08 UTC
浏览: 2057   回复: 1
Scott Flanigan
更新时间 2025-05-04 20:09:46 UTC
浏览: 1739   回复: 1
dillonhueser
更新时间 2025-05-07 19:04:41 UTC
浏览: 1710   回复: 1
更新时间 2025-05-09 12:29:14 UTC
浏览: 1875   回复: 3
Zones not turning on
Neil ONeill
更新时间 2025-05-09 12:41:28 UTC
浏览: 1822   回复: 1
Protecting whisperer from dog
更新时间 2025-05-09 17:54:44 UTC
浏览: 1852   回复: 0
Sensors missing
dano
更新时间 2025-07-06 00:06:15 UTC
Dan
浏览: 1079   回复: 1
Spark 8 zones
Jesus Laso
更新时间 2025-07-10 13:05:31 UTC
Good afternoon,
Thais in advance
浏览: 1043   回复: 1
WEATHER CONDITIONS - Rain
Zsolt Karman
更新时间 2025-07-08 10:23:15 UTC
Hi Team,
Could you please ?
Controller SN: 0cb815314670
Regards, Zsolt
浏览: 1067   回复: 1
更新时间 2025-07-10 18:58:03 UTC
Kirk
浏览: 988   回复: 1
