WEATHER CONDITIONS - Rain
Zsolt Karman
更新时间 2025-07-08 10:23:15 UTC
Hi Team,
Could you please ?
Controller SN: 0cb815314670
Regards, Zsolt
浏览: 1067   回复: 1
Sensors missing
dano
更新时间 2025-07-06 00:06:15 UTC
Dan
浏览: 1079   回复: 1
Gyade B.
更新时间 2025-07-03 23:32:35 UTC
浏览: 1125   回复: 1
Whisperer 1 Dead
更新时间 2025-07-03 15:13:13 UTC
浏览: 1085   回复: 0
Veronica Slaughter
更新时间 2025-07-03 12:43:45 UTC
浏览: 1100   回复: 0
Wifi error
nvenezia
更新时间 2025-07-02 14:51:10 UTC
浏览: 952   回复: 2
Valve not opening
更新时间 2025-07-01 05:11:54 UTC
I have a Netto controller 12
浏览: 715   回复: 1
Unified controllers
Gianluca Spada
更新时间 2025-06-29 20:59:51 UTC
浏览: 802   回复: 1
Valve compatible with Netro
Francesco Manella
更新时间 2025-06-29 10:55:38 UTC
Hi everyone,
Thanks to every can help me
浏览: 733   回复: 0
Multiple controllers — 1 app?
Jordan B
更新时间 2025-06-28 07:48:22 UTC
浏览: 828   回复: 1
Font size/ dark mode
更新时间 2025-06-28 04:53:19 UTC
浏览: 738   回复: 1
Jack De Donato
更新时间 2025-06-26 11:48:52 UTC
Question in subject title
浏览: 693   回复: 0
New Sprite Owner
Bryant Bustamante
更新时间 2025-05-26 22:46:01 UTC
浏览: 1778   回复: 1
overwatering
更新时间 2025-05-20 12:55:43 UTC
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
浏览: 1760   回复: 2
Refurbished netro controller
drylake
更新时间 2025-05-23 23:37:47 UTC
浏览: 1531   回复: 1
Battery Issue - Netro Stream
K L
更新时间 2025-05-25 03:09:56 UTC
Dear Fellows,
Device Details:
  • Hardware : Netro Stream 1.0
  • Firmware: 1.0.0
Best regards,
Kelvin
浏览: 1762   回复: 1
Mikael Hammarin
更新时间 2025-05-26 17:18:52 UTC
Suggestion:
浏览: 1742   回复: 1
Whisperer 2 Dead
更新时间 2025-05-27 23:06:05 UTC
浏览: 1787   回复: 2
Water consumption
cwo
更新时间 2025-06-01 19:51:34 UTC
浏览: 1557   回复: 1
Smart Zones are random
Dave H
更新时间 2025-05-19 15:27:46 UTC
Sprite-12
and/or
浏览: 1755   回复: 1
