Reset, but still not connecting
lorenzo s
更新时间 2024-12-19 23:36:08 UTC
Please help. I'll provide a reward for getting my N-12 to work.
lss
浏览: 2023   回复: 1
Random Start
Mario Hardy
更新时间 2024-12-23 12:56:07 UTC
浏览: 1298   回复: 1
John BAIMAY
更新时间 2024-12-26 11:35:25 UTC
Regards.
浏览: 1354   回复: 1
Zone photo
Russ McEvoy
更新时间 2024-12-28 11:29:31 UTC
Can someone help please?
浏览: 1318   回复: 1
Trevor Pfeiffer
更新时间 2024-12-26 20:05:12 UTC
Trevor Pfeiffer
浏览: 1336   回复: 1
Fat Cut
更新时间 2024-12-29 07:11:04 UTC
浏览: 1468   回复: 1
Smart Sprinkler Controlle starts then stops
Nigel Briggs
更新时间 2025-01-10 23:15:31 UTC
My controller operates but many times, rather than executing the time setting. It just cuts out?
I do have a sensor connected but I took it out of the ground to exclude wet soil feedback
I'm guessing there is a parameter forcing the stops?
Could anyone give me a direction where to look?
浏览: 1227   回复: 1
Netro Spark problem
Russ McEvoy
更新时间 2025-01-11 17:12:27 UTC
This morning my 16 zone Spark unit was showing a red LED.
The app said it was online but when I tried to manually water a zone, it just said "connecting" for the duration with nothing happening outside.
Our wifi was running as normal and the room with the controller in had a good signal.
Unplugging and plugging back in solved the problem but it doesn't leave me with much confidence of the unit if it's going to do this at a critical time of year without being noticed.
Is there a reliability issue with the latest firmware?
浏览: 1317   回复: 1
Nigel Briggs
更新时间 2025-01-15 10:05:07 UTC
Why ?
浏览: 1750   回复: 1
Pixie - Z1
Steve Inwood
更新时间 2025-01-16 10:10:53 UTC
浏览: 1233   回复: 1
Netro offline
Brett Gardner
更新时间 2025-01-20 00:02:43 UTC
Suggestions?
Hard reset?
Brett
浏览: 1309   回复: 1
W4MSolutions
更新时间 2025-01-23 17:32:49 UTC
浏览: 1318   回复: 1
Discount
darla
更新时间 2025-01-30 20:05:17 UTC
Darla Carpenter
浏览: 1167   回复: 1
Door came off the unit
Michael Riley
更新时间 2025-02-19 19:52:51 UTC
浏览: 1013   回复: 1
Mike Carey
更新时间 2025-03-02 17:48:24 UTC
浏览: 944   回复: 1
Water transfer during rain
mark spencer
更新时间 2025-03-12 02:34:42 UTC
Is there a way?
浏览: 817   回复: 1
Tiempo de riego
Doyle Farm
更新时间 2025-03-16 17:30:27 UTC
Gracias Marcelo
浏览: 813   回复: 1
Greenhouse
Perry en Louise Mevissen
更新时间 2025-03-22 08:43:22 UTC
One of our sectors runs inside a greenhouse now. Apart from soil type and sprinkler head type, does anyone have advice how to optimise sector settings for this situation? I feel the influence of sun and normal outdoor temperature is different, and rain is completely absent in this sector.
May I suggest to add some sector setting that it is inside a greenhouse?
Perry
浏览: 729   回复: 1
Dutch language improvement
更新时间 2025-03-22 08:54:24 UTC
Kind regards,
Perry
浏览: 738   回复: 1
Netro Whisperer gen2 4 zones
Luca Gennuso
更新时间 2025-03-25 22:22:40 UTC
浏览: 752   回复: 1
