更新时间 2023-06-27 22:03:51 UTC
浏览: 3809   回复: 1
COUNTRY PROBLEM
mario_chieppa
更新时间 2023-06-28 07:10:08 UTC
Hi, trying to register my geographical position (in Italy) I don't have the possibility to modify the fields in the photo, remaining in the USA.  For this reason the application time is totally wrong.  How can I fix?
Salve, cercando di registrare la mia posizione geografica ( in italia) non ho la possibilità di modificare i campi in foto, rimanendo USA. Per questo motivo l'orario dell'applicazione è totalmente sbagliato. Come posso risolvere?
浏览: 4288   回复: 1
Battery LED Blinking
E B
更新时间 2023-06-29 15:33:28 UTC
浏览: 4049   回复: 1
Previsioni meteo sbagliate
Manuel Mancini
更新时间 2023-07-01 15:59:30 UTC
浏览: 3562   回复: 2
Spanish translation problem
Abraio
更新时间 2023-07-02 20:49:46 UTC
Greetings from Spain.
浏览: 3553   回复: 1
Moisture level
更新时间 2023-07-03 00:49:48 UTC
Rained hatd in my area but the moisture level is still in the teen, is there a way I can change my zones to 100% moisture?
浏览: 4398   回复: 1
Cambio días de demora.
Lino
更新时间 2023-07-03 06:35:04 UTC
浏览: 3562   回复: 2
Not enough watering
Manuel Herbst
更新时间 2023-07-03 20:19:28 UTC
Hey everybody,
Can anybody help me?
Manuel
浏览: 3882   回复: 1
LOAD ISSUE NOTIFICATION
Javier NM
更新时间 2023-07-04 11:25:43 UTC
浏览: 3890   回复: 1
Can't reconnect wifi
Yuriy Andamasov
更新时间 2023-07-05 21:14:40 UTC
sprite-6 went offline
never pass step 5
worked just fine almost year
浏览: 3742   回复: 1
Michael Burberry
更新时间 2023-07-05 22:39:33 UTC
浏览: 3551   回复: 1
John Zuzula
更新时间 2023-07-06 22:57:53 UTC
浏览: 3944   回复: 2
Bruno
更新时间 2023-07-07 22:09:44 UTC
浏览: 3905   回复: 1
Moisture and weather API
Andrea D.
更新时间 2023-07-07 23:20:33 UTC
Hello there,
浏览: 3763   回复: 2
Pixie Z1
ke7vng
更新时间 2023-07-08 02:25:00 UTC
浏览: 3469   回复: 1
Why no cycle soak setting?
更新时间 2023-07-08 19:56:33 UTC
浏览: 3815   回复: 1
Restrictions
Mark Killeen
更新时间 2023-07-10 22:48:23 UTC
浏览: 3681   回复: 0
Restrictions
Mark Killeen
更新时间 2023-07-10 22:48:36 UTC
浏览: 3735   回复: 1
更新时间 2023-07-11 12:26:26 UTC
浏览: 4021   回复: 1
Warranty
BOBBY BROWNE
更新时间 2023-07-11 17:32:17 UTC
浏览: 3611   回复: 1
