Malfunzionamento durata irrigazione
MarcoPolinari
更新时间 2023-06-25 21:45:29 UTC
Buonasera,
quando avvio l'irrigazione, sia in manuale che in automatico, la centralina attiva per circa 2 secondi la zona e la pompa e poi si spegne, mentre  dal APP sembra che proceda tutto regolarmente.
浏览: 2937   回复: 1
更新时间 2023-06-26 12:06:15 UTC
  1.  it's raining or
浏览: 2870   回复: 1
更新时间 2023-06-27 08:48:51 UTC
浏览: 2855   回复: 1
Connection issue
Federica Musmanno
更新时间 2023-06-27 12:16:35 UTC
浏览: 2662   回复: 1
更新时间 2023-06-27 22:03:51 UTC
浏览: 2847   回复: 1
COUNTRY PROBLEM
mario_chieppa
更新时间 2023-06-28 07:10:08 UTC
Hi, trying to register my geographical position (in Italy) I don't have the possibility to modify the fields in the photo, remaining in the USA.  For this reason the application time is totally wrong.  How can I fix?
Salve, cercando di registrare la mia posizione geografica ( in italia) non ho la possibilità di modificare i campi in foto, rimanendo USA. Per questo motivo l'orario dell'applicazione è totalmente sbagliato. Come posso risolvere?
浏览: 3334   回复: 1
Battery LED Blinking
E B
更新时间 2023-06-29 15:33:28 UTC
浏览: 3057   回复: 1
Previsioni meteo sbagliate
Manuel Mancini
更新时间 2023-07-01 15:59:30 UTC
浏览: 2668   回复: 2
Spanish translation problem
Abraio
更新时间 2023-07-02 20:49:46 UTC
Greetings from Spain.
浏览: 2651   回复: 1
Moisture level
更新时间 2023-07-03 00:49:48 UTC
Rained hatd in my area but the moisture level is still in the teen, is there a way I can change my zones to 100% moisture?
浏览: 3413   回复: 1
Cambio días de demora.
Lino
更新时间 2023-07-03 06:35:04 UTC
浏览: 2662   回复: 2
Not enough watering
Manuel Herbst
更新时间 2023-07-03 20:19:28 UTC
Hey everybody,
Can anybody help me?
Manuel
浏览: 2930   回复: 1
LOAD ISSUE NOTIFICATION
Javier NM
更新时间 2023-07-04 11:25:43 UTC
浏览: 2951   回复: 1
Can't reconnect wifi
Yuriy Andamasov
更新时间 2023-07-05 21:14:40 UTC
sprite-6 went offline
never pass step 5
worked just fine almost year
浏览: 2813   回复: 1
Michael Burberry
更新时间 2023-07-05 22:39:33 UTC
浏览: 2669   回复: 1
John Zuzula
更新时间 2023-07-06 22:57:53 UTC
浏览: 2994   回复: 2
Bruno
更新时间 2023-07-07 22:09:44 UTC
浏览: 2937   回复: 1
Moisture and weather API
Andrea D.
更新时间 2023-07-07 23:20:33 UTC
Hello there,
浏览: 2817   回复: 2
Pixie Z1
ke7vng
更新时间 2023-07-08 02:25:00 UTC
浏览: 2584   回复: 1
Why no cycle soak setting?
更新时间 2023-07-08 19:56:33 UTC
浏览: 2835   回复: 1
