Pixie Z1
Jason Willis
更新时间 2023-05-02 14:13:57 UTC
Jason Willis
Jason@wishsystems.biz
浏览: 2548   回复: 1
Michael Cayless
更新时间 2023-05-03 15:45:48 UTC
浏览: 2557   回复: 1
Francesco Zorzetto
更新时间 2023-05-05 23:09:14 UTC
浏览: 2441   回复: 1
Rain delay
David M.
更新时间 2023-05-07 04:30:25 UTC
I made a mistake on my netro spark and included a rain delay from the main screen.
How can I delete this delay?
浏览: 2750   回复: 1
Alvaro Guardado
更新时间 2023-05-08 18:25:58 UTC
Dear support,
浏览: 2278   回复: 1
Whisperer GPS error
Guido Minciotti
更新时间 2023-05-10 15:11:55 UTC
浏览: 2623   回复: 1
No light
Gabriele Gualtieri
更新时间 2023-05-10 17:13:50 UTC
浏览: 2591   回复: 1
Bruno
更新时间 2023-05-10 22:41:29 UTC
浏览: 2716   回复: 1
Anupam Kumar
更新时间 2023-05-11 00:29:18 UTC
浏览: 2284   回复: 1
Nitro speak to system
Charlie Patel
更新时间 2023-05-11 18:55:33 UTC
浏览: 2342   回复: 1
Whisperer wifi connection
Paolo S
更新时间 2023-05-12 15:41:24 UTC
Any suggestion?
Any issue with iphone 14?
浏览: 2491   回复: 1
S R
更新时间 2023-05-13 00:02:22 UTC
浏览: 4111   回复: 2
更新时间 2023-05-14 12:23:35 UTC
Kirk
浏览: 2717   回复: 1
Jim Shields
更新时间 2023-05-15 21:20:33 UTC
浏览: 2444   回复: 1
Days not appearing on 6-days a week schedule
Rec Tift
更新时间 2023-05-17 02:40:49 UTC
Our watering restrictions are on 6-days a week. Thursday, Friday, and Saturday do not show water schedule. How do I add these days to program?
浏览: 2681   回复: 1
Richard Nibbler
更新时间 2023-05-17 02:50:09 UTC
Tyvm
浏览: 2680   回复: 3
Problem in Netro app in my iPhone
Manel Barbero
更新时间 2023-05-18 08:21:17 UTC
I had installed an irrigation controller and one plant sensor and it worked OK. Since I have added one Pixie-1 and one Pixie-Z1, on the app screen when I try to enter innthe red ring bell to see notifications, I am thrown out the app and I can’t see my notifications.
浏览: 2917   回复: 1
Watering problem
Marco Nicosia
更新时间 2023-05-21 10:35:08 UTC
Does it happen to anyone that sometimes the irrigation starts by itself despite the program being set to manual?
浏览: 2385   回复: 1
App Showing Ofline
Katie Wallace
更新时间 2023-05-21 11:09:21 UTC
浏览: 2271   回复: 1
Mismatch zones/times
Jose R
更新时间 2023-05-21 12:40:53 UTC
So happy with how this works.
浏览: 2351   回复: 1
