Certificate Expired - AGAIN!
AllenHome
更新时间 2023-06-11 06:42:24 UTC
浏览: 2547   回复: 1
Netro sprite
mekanicul Meku
更新时间 2023-06-11 09:43:07 UTC
浏览: 2487   回复: 1
Apollon16
更新时间 2023-06-12 12:25:08 UTC
Apollon16
浏览: 3364   回复: 1
Beau Cook
更新时间 2023-06-12 23:10:58 UTC
浏览: 2636   回复: 1
Delay settings
Roberto Pirovano
更新时间 2023-06-13 09:15:35 UTC
浏览: 2809   回复: 1
Calibrating sprinkler output
SonDeMar
更新时间 2023-06-13 15:16:54 UTC
浏览: 2670   回复: 1
No notifications
Khalid Mousa
更新时间 2023-06-14 03:25:18 UTC
浏览: 2883   回复: 1
Pixie-Z1-H - How to install?
kernel
更新时间 2023-06-14 15:54:05 UTC
  • I have received a new Pixie-Z1 and a hub
  • Downloaded the Netro iOS App from the UK app store
  • In the App I added the hub connecting through Bluetooth and configuring WiFi access for the hub
  • Hub shows constant green light
Now how can I add the Pixie-Z1 hose faucet to my account? The App only shows the option for the Pixie-1, which doesn't work because the Pixie-Z1 uses the Zigbee connection, not WiFi.
浏览: 3750   回复: 1
zoe
更新时间 2023-06-15 00:40:38 UTC
Linda Lundgren
浏览: 2737   回复: 1
Rainy day shut off
更新时间 2023-06-16 13:18:25 UTC
浏览: 2862   回复: 1
Zone doesn't stay on
Brent S
更新时间 2023-06-18 02:05:28 UTC
Hi just installed a sprite 6. I can here zone turn on then immediately turns off but the timer is still running on the app. I can hear the water stop and start in each zone ; the app thinks it's watering but the valve closes. Same for all zones
Thansk
浏览: 2963   回复: 1
Luis T
更新时间 2023-06-18 15:30:17 UTC
Any comments are welcome.
浏览: 3865   回复: 3
更新时间 2023-06-19 09:25:40 UTC
浏览: 3017   回复: 2
Disconnessione
Carlo Capraro
更新时间 2023-06-19 12:11:17 UTC
Grazie a tutti
浏览: 2568   回复: 1
Massimo Oldrini
更新时间 2023-06-20 07:57:16 UTC
Buongiorno,
L’apparato va sostituito?
浏览: 2677   回复: 2
Start-end time not working
Fabio Silvestri
更新时间 2023-06-21 05:20:31 UTC
浏览: 2933   回复: 3
Zones not watering
joefil
更新时间 2023-06-22 16:54:38 UTC
Your help is appreciated
浏览: 2731   回复: 1
Ralph G
更新时间 2023-06-23 18:56:48 UTC
浏览: 2828   回复: 1
120 Sweet Bailey
更新时间 2023-06-23 23:14:09 UTC
浏览: 2651   回复: 1
Malfunzionamento durata irrigazione
MarcoPolinari
更新时间 2023-06-25 21:45:29 UTC
Buonasera,
quando avvio l'irrigazione, sia in manuale che in automatico, la centralina attiva per circa 2 secondi la zona e la pompa e poi si spegne, mentre  dal APP sembra che proceda tutto regolarmente.
浏览: 2937   回复: 1
