Controller location
Francesco Zorzetto
更新时间 2023-05-29 13:55:31 UTC
Hi, during the installation phase of the controller, it was not possible to change the position regarding the geographical state of the machine, a US state remains by default and consequently, I can assume, the start times of the irrigation cycles are carried out with the time zone american time. How can I fix it?
浏览: 3149   回复: 1
Arturo Camin
更新时间 2023-05-30 09:17:10 UTC
浏览: 2741   回复: 1
New grass from seed
D Berggren
更新时间 2023-05-31 01:11:58 UTC
浏览: 2586   回复: 1
Corinne Cleary
更新时间 2023-06-01 00:55:20 UTC
Please help.
浏览: 2549   回复: 1
kaitech
更新时间 2023-06-01 19:44:40 UTC
How can I troubleshoot it?
浏览: 2532   回复: 1
Smart mode initial watering
Matt Ward
更新时间 2023-06-02 01:19:52 UTC
浏览: 2817   回复: 1
Nero Sprite
Glenn Thurston
更新时间 2023-06-02 12:12:10 UTC
浏览: 2539   回复: 1
Power
nvenezia
更新时间 2023-06-02 18:10:49 UTC
浏览: 2961   回复: 1
D Hitch
更新时间 2023-06-03 14:10:58 UTC
Thanks for any help.
浏览: 2643   回复: 1
Börke Titscher
更新时间 2023-06-04 08:32:03 UTC
Folks
浏览: 2685   回复: 2
2 zones not working
Shahid Habib
更新时间 2023-06-05 13:39:04 UTC
Any help will be appreciated.
浏览: 2933   回复: 3
Adil Ridvan
更新时间 2023-06-08 04:44:28 UTC
Pros:
Cons:
Adil
浏览: 3467   回复: 1
Change Country
samhye
更新时间 2023-06-08 12:58:01 UTC
Hello all,
Many thanks.
浏览: 2639   回复: 1
Netro sprite chpset.
Eduardo Pariente
更新时间 2023-06-09 18:15:24 UTC
Hello everyone.
Thanks you.
浏览: 2722   回复: 1
Eduardo Pariente
更新时间 2023-06-09 18:15:34 UTC
Hello everyone.
Thanks you.
浏览: 2562   回复: 0
Whisperer sensor
更新时间 2023-06-10 17:39:10 UTC
浏览: 2904   回复: 1
更新时间 2023-06-10 17:50:24 UTC
浏览: 2797   回复: 1
Srdjan
更新时间 2023-06-11 05:21:33 UTC
浏览: 2806   回复: 2
Problem with APP connection
Davide G.
更新时间 2023-06-11 05:49:55 UTC
浏览: 2796   回复: 2
Certificate error
ventinovesette
更新时间 2023-06-11 06:03:25 UTC
浏览: 2838   回复: 2
