Netro phone app won't open
Christopher Scarborough
更新时间 2023-07-30 23:32:37 UTC
浏览: 2657   回复: 1
Tim Quach
更新时间 2023-08-01 08:02:49 UTC
浏览: 2622   回复: 1
Atif Siddiqui
更新时间 2023-08-02 04:51:58 UTC
浏览: 2680   回复: 1
Using Bootlace ferrules.
Bob Howard
更新时间 2023-08-03 06:36:09 UTC
I'd like to use bootlace ferrules for all the wiring to the sprite as shown in your installation video (power connection). I'm using 0.5mm² x 7 core cable and 0.5mm² bootlaces and the unit won't grip them. I've tried other sizes with the same result. What size ferrule is required?
浏览: 3356   回复: 1
Date format
Bob Howard
更新时间 2023-08-03 23:27:42 UTC
浏览: 2939   回复: 1
David H
更新时间 2023-08-04 17:15:09 UTC
浏览: 2739   回复: 1
App show’s pending message
Greg Jones
更新时间 2023-08-07 18:46:13 UTC
浏览: 2921   回复: 1
Drew M
更新时间 2023-08-08 17:48:40 UTC
浏览: 2586   回复: 1
We had 4 inches of rain
更新时间 2023-08-09 03:08:18 UTC
浏览: 2815   回复: 2
Cambio wifi
jmgrau
更新时间 2023-08-09 15:10:03 UTC
Espero su ayuda.
浏览: 2431   回复: 1
App is not installing
Martin Trevino
更新时间 2023-08-09 16:40:50 UTC
浏览: 2676   回复: 1
Louise Brinkman
更新时间 2023-08-10 05:52:23 UTC
浏览: 2842   回复: 1
Spark and Sensors
C He
更新时间 2023-08-10 06:45:57 UTC
Hi all,
Thanks for support!
浏览: 2807   回复: 1
Calendar View
更新时间 2023-08-10 11:23:26 UTC
Netro Support Team,
Houston, Texas
浏览: 2789   回复: 1
technic support
Isabel Santillan
更新时间 2023-08-11 07:07:33 UTC
浏览: 2504   回复: 1
Kay Fluhr
更新时间 2023-08-11 17:07:54 UTC
Hi there
浏览: 2622   回复: 2
Pixie
Charles Schatz
更新时间 2023-08-12 15:53:10 UTC
How do I synch my pixie without having to wait for the scheduled time?
浏览: 2637   回复: 1
Louise Brinkman
更新时间 2023-08-12 23:01:10 UTC
浏览: 2826   回复: 1
C He
更新时间 2023-08-13 11:54:36 UTC
Whats wrong?
浏览: 2765   回复: 1
Aspensprinklers
更新时间 2023-08-13 23:37:32 UTC
浏览: 2614   回复: 1
