carlos davalos melgar
更新时间 2023-04-13 20:07:05 UTC
浏览: 3144   回复: 1
Matt Ward
更新时间 2023-04-14 13:57:11 UTC
Matt
浏览: 2630   回复: 3
Intelligent mode useless
Juan Lambea
更新时间 2023-04-14 15:51:37 UTC
浏览: 3435   回复: 1
dummy serial for testing
更新时间 2023-04-16 17:53:00 UTC
浏览: 2693   回复: 1
Multiple users
Norm Markworth
更新时间 2023-04-17 00:22:59 UTC
Norm
浏览: 3123   回复: 2
Pixie keeps disconnecting
Sang Peiris
更新时间 2023-04-18 12:44:42 UTC
浏览: 2571   回复: 1
Add user Error
更新时间 2023-04-21 09:26:43 UTC
浏览: 2345   回复: 2
farenheit to celsius
Santiago Moller
更新时间 2023-04-22 02:41:55 UTC
Hello, I need help to change the settings from Fahrenheit to Celsius in the app, I have a smart plant sensor.  Thank you
浏览: 3024   回复: 1
Area
Javier Domínguez
更新时间 2023-04-22 16:04:10 UTC
Hola,
Cuando estoy configurando las zonas me pide un valor de area, ¿en qué medida? ¿Metros cuadrados?
浏览: 2563   回复: 1
valves under relay
Alek
更新时间 2023-04-22 17:48:29 UTC
浏览: 3384   回复: 1
Master error “open circuit”
Neil Lucey
更新时间 2023-04-24 14:09:12 UTC
Neil
浏览: 2468   回复: 1
更新时间 2023-04-24 14:27:08 UTC
Sprite / app
Never before
Disconnection to wifi
Even when say : online
irrigation )
浏览: 2791   回复: 1
Jim
更新时间 2023-04-24 17:38:25 UTC
浏览: 2681   回复: 2
Katie Woggins
更新时间 2023-04-24 18:40:07 UTC
浏览: 2437   回复: 1
0 Minute Zones?
Stephen Wyatt
更新时间 2023-04-26 12:59:02 UTC
浏览: 2266   回复: 1
How to cancel schedule
Wayne Curdy
更新时间 2023-04-27 01:15:38 UTC
浏览: 2293   回复: 1
Purchasing in the UK
Phil Middleton
更新时间 2023-04-27 21:05:51 UTC
I have purchased Netro Sprite from Amazon. I'm now trying to purchase a couple of Whisperer units. Is there anywhere in the UK as purchasing from the online shop the delivery charge is over $26.
Phil
浏览: 2873   回复: 1
Alexa
Federico Gietz
更新时间 2023-04-30 15:28:52 UTC
浏览: 2409   回复: 1
Pixie connection
Sarroniz
更新时间 2023-05-01 06:20:22 UTC
I already have the Sprite 12 and want to add one or two Pixies.
Do I need the hub for the pixie or the sprite12 acts as hub?
Sergio
浏览: 2741   回复: 1
Suggestion
Tom Carn
更新时间 2023-05-01 17:01:12 UTC
浏览: 2276   回复: 1
