Veronica Slaughter
更新时间 2022-10-01 05:11:02 UTC
Any insight is so welcome!
浏览: 2862   回复: 1
Discover and weather accuracy
Geron R
更新时间 2022-10-01 12:38:37 UTC
浏览: 2971   回复: 1
No connection to WiFi.
Gianluca De Virgilio
更新时间 2022-10-02 21:48:54 UTC
Good afternoon.
浏览: 3434   回复: 2
Main feeder line shutoff valve control
Richard Miles
更新时间 2022-10-10 02:16:36 UTC
My main water line to the sprinkler system came loose and flooded my vacation home yard with 250,000 gallons of water before the leak was discovered and repaired.  Does Netro have the ability to control an electric valve on this feeder line such that the main valve will only open when the irrigation system calls for water?
浏览: 2877   回复: 1
Weather station
更新时间 2022-10-14 02:07:16 UTC
浏览: 3179   回复: 1
Water pressure
Omer Zadikevitch
更新时间 2022-10-18 18:15:38 UTC
浏览: 2802   回复: 1
更新时间 2022-10-20 14:57:19 UTC
Thanks for your advice
浏览: 2846   回复: 1
Water valve opened
Paolo Talamelli
更新时间 2022-10-23 10:52:29 UTC
浏览: 2639   回复: 1
Cutrone
更新时间 2022-10-25 17:06:24 UTC
Hello all!
浏览: 3220   回复: 2
Daniel Gajardo
更新时间 2022-10-27 01:22:57 UTC
浏览: 2911   回复: 1
Percentage Adjustment
jeremyagrelius@gmail.com
更新时间 2022-10-29 18:31:12 UTC
浏览: 2772   回复: 1
LearNetro Whisperer
更新时间 2022-10-30 19:15:38 UTC
At the end of the whisperer's learning time, the times are set automatically in the program or have to be done manually?
浏览: 3163   回复: 2
Gianluca Bus
更新时间 2022-11-03 12:03:59 UTC
Hi all!
Netro App vesion: 3.1.0
Netro controller hw ver.: 1.2
Thanks in advance.
Gianluca
浏览: 2725   回复: 1
Carlo Drago
更新时间 2022-11-04 18:48:50 UTC
Carlo
浏览: 2771   回复: 1
Netro light
Alessandro Zannini
更新时间 2022-11-05 20:16:40 UTC
浏览: 2530   回复: 1
更新时间 2022-11-06 13:30:47 UTC
浏览: 3230   回复: 2
Reset whisperer
Omer Zadikevitch
更新时间 2022-11-07 17:05:32 UTC
How do I reset the whisperer
浏览: 2709   回复: 1
Manual Mode not working
Gary C
更新时间 2022-11-08 23:30:48 UTC
浏览: 2781   回复: 2
Nathan Craig
更新时间 2022-11-11 13:11:38 UTC
浏览: 2675   回复: 1
Shut down for winter
A Smith
更新时间 2022-11-11 20:42:28 UTC
浏览: 2526   回复: 1
