Whisperer too weak
更新时间 2022-08-19 21:10:55 UTC
Hi there
浏览: 3079   回复: 1
Total reset
Azrandy
更新时间 2022-08-20 17:23:56 UTC
How do you do a total reset?
Seamed to be stuck ?
浏览: 2750   回复: 1
更新时间 2022-08-21 09:13:22 UTC
浏览: 3005   回复: 1
Can Pixie measure water flow?
更新时间 2022-08-23 14:09:01 UTC
浏览: 2951   回复: 1
Kasper Huber
更新时间 2022-08-24 13:15:29 UTC
浏览: 2824   回复: 1
Clock on sprite
Rory
更新时间 2022-08-24 19:43:30 UTC
浏览: 2691   回复: 1
texan4ever521
更新时间 2022-08-24 20:24:11 UTC
My settings :
soil type: clay
sprinkler type: rotor head
shade: none or some shade
浏览: 3163   回复: 1
How can add zones
Veronica Slaughter
更新时间 2022-08-25 04:20:46 UTC
浏览: 2813   回复: 1
Suspect a shorted solenoid
rbrodt
更新时间 2022-08-25 16:00:32 UTC
I bought a Netro Spark to replace an existing controller (a Raspberry pi based Open Sprinkler system) which exploded probably due to a shorted solenoid.
I read that the Spark can detect solenoids that are drawing too much current; is it safe to connect the Spark to shorted solenoids without worrying about damage to the controller?
Should I test all the solenoids with an amp meter first just to make sure?
浏览: 3469   回复: 1
rbrodt
更新时间 2022-08-25 16:29:00 UTC
浏览: 2982   回复: 1
Wunderground
Brian Strickler
更新时间 2022-08-25 16:43:35 UTC
How can I get station id
KMTJOLIE28
Added to my controller
浏览: 2899   回复: 1
Soil
Stephen Brewer
更新时间 2022-08-27 12:11:15 UTC
Many thanks in advance
浏览: 3859   回复: 1
Manual watering
Hadeel Hammodat
更新时间 2022-08-29 02:22:09 UTC
浏览: 2734   回复: 1
App locks up
更新时间 2022-08-29 08:39:41 UTC
Please advise.
浏览: 3023   回复: 1
Error in watering ?
Davide M.
更新时间 2022-08-29 11:31:56 UTC
Please help me:
  1.  what should I trust ?
APP:
WEB:
浏览: 3065   回复: 1
A Gallo
更新时间 2022-08-29 14:28:38 UTC
浏览: 2932   回复: 1
IFTTT out of sync
更新时间 2022-08-30 07:08:46 UTC
Please advise.
浏览: 3118   回复: 2
Program
Bob Neal
更新时间 2022-08-31 17:11:55 UTC
浏览: 2866   回复: 1
Random sprinklers turn on
Brian Strickler
更新时间 2022-09-01 12:33:12 UTC
浏览: 3032   回复: 2
Help! Pump Relay Question
更新时间 2022-09-01 13:43:25 UTC
My unit has been working great . However, the relay no longer trips when a zone is activated. Am I supposed to have 24v A/C between M and C (on the right side of the panel, not the zone side) when a zone is active? I can trip the relay if I pull it from the Netro. Some sort of voltage output map would be helpful.
I have new grass seed down, so please help soon.
浏览: 4229   回复: 1
