Manual runs overriding schedule
unislock
更新时间 2022-07-07 12:02:15 UTC
Is there a way to not have manual runs conflict with the smart schedule?  At times I turn sprinklers on for kids to have fun or to test a newly installed head for a few minutes. These manual runs (even for a minute or two) in these zones are not being run during the next scheduled run. This is frustrating and now I need to do a lot of manual runs to ensure lawn gets appropriate amount of water and is basically taking away my ability to auto schedule.
Thoughts?
浏览: 3265   回复: 2
Smart watering settings
SK Breuer
更新时间 2022-07-07 17:34:52 UTC
浏览: 2696   回复: 1
Zones cut out
tbbucans
更新时间 2022-07-08 00:44:31 UTC
浏览: 2604   回复: 1
Frank Fang
更新时间 2022-07-08 18:44:28 UTC
浏览: 2614   回复: 1
WU weather provider question
Weston Hull
更新时间 2022-07-09 01:43:02 UTC
浏览: 2727   回复: 1
Want to use two controllers
dl74pw@yahoo.com
更新时间 2022-07-09 14:19:31 UTC
浏览: 2620   回复: 1
Power device heat
David Domingues
更新时间 2022-07-09 17:15:45 UTC
Hello all,
I just bought a Netro controller with only 2 areas setup and I like it so far.
I was wondering if the noise and heat from the power supply was a  normal thing to happen.
Thanks in advance.
浏览: 3523   回复: 2
更新时间 2022-07-10 11:25:02 UTC
浏览: 2951   回复: 1
Day view
更新时间 2022-07-12 04:10:37 UTC
浏览: 2814   回复: 1
Netro connection to IFTTT
Sarah Kottke
更新时间 2022-07-12 13:44:09 UTC
Anyone had luck?
Sarah
浏览: 2874   回复: 1
More data
Jim Shaffer
更新时间 2022-07-13 13:06:30 UTC
浏览: 2933   回复: 1
Plant sensor
Miro D
更新时间 2022-07-14 10:42:35 UTC
浏览: 2920   回复: 1
Waters excessively
Cindy Luvender
更新时间 2022-07-14 16:38:38 UTC
浏览: 3075   回复: 1
Pixie water pressure
Chris
更新时间 2022-07-15 09:03:05 UTC
浏览: 2848   回复: 1
更新时间 2022-07-15 12:27:12 UTC
浏览: 3410   回复: 2
更新时间 2022-07-15 13:56:02 UTC
浏览: 3084   回复: 2
David Domingues
更新时间 2022-07-16 17:16:14 UTC
Hello.
浏览: 3656   回复: 5
Controller LED Light
Don Carli
更新时间 2022-07-18 00:16:22 UTC
浏览: 2815   回复: 1
Zone won't shut off
chesh235
更新时间 2022-07-18 18:53:38 UTC
浏览: 3088   回复: 2
Home Assistant integration
更新时间 2022-07-19 01:24:57 UTC
浏览: 3083   回复: 1
