Battery in Pixie Reads 282%
David Halpern
更新时间 2022-05-21 13:50:23 UTC
浏览: 3216   回复: 2
更新时间 2022-05-21 17:31:03 UTC
浏览: 3220   回复: 1
malfunction
Ramón Sellés
更新时间 2022-05-22 10:28:57 UTC
volume_up
content_copy
share
浏览: 2828   回复: 1
MQTT port is blocked
Jose Juan Dios
更新时间 2022-05-22 11:51:44 UTC
Can you help me please?
Thankyou
浏览: 3043   回复: 1
更新时间 2022-05-23 14:33:07 UTC
浏览: 3959   回复: 1
Meteo app
Enrico Marion
更新时间 2022-05-23 17:03:37 UTC
浏览: 2899   回复: 1
Night watering
John Kot
更新时间 2022-05-23 21:15:34 UTC
浏览: 3160   回复: 1
Bayoule Bayoule
更新时间 2022-05-24 18:50:51 UTC
JM
浏览: 2841   回复: 2
Wayne Smith
更新时间 2022-05-24 20:51:31 UTC
浏览: 2881   回复: 1
Pixie wifi connection
Luis Borrás
更新时间 2022-05-25 05:58:44 UTC
Luis
浏览: 2713   回复: 1
Discover irrigation
更新时间 2022-05-25 06:52:34 UTC
浏览: 3017   回复: 1
milanese
更新时间 2022-05-27 02:32:57 UTC
iPhone -
- Get app
- Crete account
- Go to connect timer
- Next
- Enter name and stuff, next
- Turn on unit, next
Please advise.
浏览: 2825   回复: 1
Connection issues
Ant Va
更新时间 2022-05-27 09:57:09 UTC
浏览: 3247   回复: 3
Netro screwed up
Jack Davis
更新时间 2022-05-28 16:14:25 UTC
浏览: 3116   回复: 1
Schedule is empty?
Jacopo De Simoi
更新时间 2022-05-29 02:44:51 UTC
Best
 Jacopo
浏览: 2976   回复: 1
Val Smith
更新时间 2022-06-30 23:53:11 UTC
浏览: 3054   回复: 2
Val Smith
更新时间 2022-06-30 23:52:31 UTC
浏览: 3163   回复: 1
Schedule screen
Dick Milde
更新时间 2022-05-30 14:02:03 UTC
浏览: 2729   回复: 1
Setting up the schedule
Sasha Obradovic
更新时间 2022-05-30 22:11:58 UTC
I’m trying to setup schedule for watering for next five months, But watering schedule shows only for two next months. I check the settings and I do have a selected five next month. is there something I’m not doing right?
浏览: 3437   回复: 2
Andy Ricco
更新时间 2022-05-31 06:12:27 UTC
浏览: 3270   回复: 1
