Watering days
更新时间 2022-04-16 18:22:19 UTC
Home display is correct and shows Last watering the day before at the date and time in the program (watering planned everyday) but under Discover many days are shown as if there has not been any irrigation.
What could be the reason why ?
浏览: 3292   回复: 2
Feature Request
Tod Johnson
更新时间 2022-04-16 18:22:20 UTC
浏览: 2626   回复: 1
Gaspare Miceli
更新时间 2022-04-18 06:23:55 UTC
浏览: 4014   回复: 1
Alessandro Malaguti
更新时间 2022-04-18 10:04:06 UTC
I attach mp4 link
浏览: 2522   回复: 1
Wifi connection
更新时间 2022-04-18 11:31:15 UTC
浏览: 2911   回复: 1
Netro lose wifi connection
Rob Rossi
更新时间 2022-04-19 09:22:12 UTC
If I restart the router,
how can it be solved?
浏览: 2731   回复: 1
John Lillistone
更新时间 2022-04-19 11:26:49 UTC
浏览: 2768   回复: 1
Davide M.
更新时间 2022-04-20 09:23:18 UTC
Good day all,
Thanks for help.
Davide
浏览: 2971   回复: 1
ITA Translation
Davide M.
更新时间 2022-04-20 07:21:19 UTC
Hi all,
Best Regards,
Davide
浏览: 2879   回复: 1
Blinking light on my Netro
RMeador
更新时间 2022-04-21 01:20:07 UTC
浏览: 2511   回复: 1
doppia irrigazione
mauro croce
更新时间 2022-04-22 10:52:27 UTC
浏览: 3012   回复: 1
Whisper Sensor
Ian Moore
更新时间 2022-04-26 02:55:10 UTC
浏览: 3001   回复: 1
Brian Brun
更新时间 2022-04-26 04:23:12 UTC
浏览: 2958   回复: 1
Calendar won’t update
Yuanchao X
更新时间 2022-04-26 19:44:49 UTC
浏览: 2648   回复: 2
J H
更新时间 2022-04-26 20:17:38 UTC
浏览: 2794   回复: 1
Activity not showing on ap
Mark Killeen
更新时间 2022-04-27 15:21:38 UTC
浏览: 2930   回复: 1
Netro Whisperer
Fabrice GOUFFRAN
更新时间 2022-04-28 12:29:53 UTC
I am unable to have my new whisperer working. It doesn’t light on even after half a day under the sun.
浏览: 3506   回复: 1
Incorrect rainfall accumulation
rwflower
更新时间 2022-04-29 16:35:33 UTC
I live in Katy Texas and have been using the Netro water controller in smart mode for over 2 years with no problems.  We received at least 1.5in of rain on the April 25, so I was dismayed to find my sprinkler system watering my yard on the morning of the 26th.  The rain graph in the app is showing 0.03in for the 25th and is clearly wrong.  I have tried changing to all the different weather providers, but the total rain accumulation doesn't change.  The frontal system that caused the rain passed over the entire area, so this is not a situation of local shower only affecting a localized area.
浏览: 3205   回复: 2
Location outside USA
Eduardo Prieto
更新时间 2022-04-30 09:45:16 UTC
I live in Spain and ubication selector do not let me specify my correcto location. I assume It is requieres to provide the Meteorological service the place where to predict weather, so if location is incorrect, the weather too and the watering planning is not optimized properly.
Please work It out un Next app releases.
浏览: 2873   回复: 1
Dhar Sawh
更新时间 2022-05-01 13:26:09 UTC
Dhar
浏览: 2962   回复: 2
