No restrictions set, yet program is skipping because of user restrictions
alan.ashby
更新时间 2022-01-02 11:40:53 UTC
I have no restrictions set, yet the app is indicating that restrictions are set and scheduled days are being skipped when they should not be.  Please see app screen shots.
浏览: 2873   回复: 1
Weather not updating
Mick Faulks
更新时间 2022-01-05 00:20:42 UTC
NetroWeather not updating, other weather apps only update if they are resubmitted every couple of days, is it possible to add other weather providers to the app?
浏览: 3300   回复: 2
i have problem with netro sprite 6
Nguyễn Vinh
更新时间 2022-01-06 04:51:41 UTC
I am a distributor of netro products in Vietnam market
My customer just sent back a product with a burnt electronic device inside (pictured). can you tell me what the possible reason is and how to fix it.
- 220V (stable) power supply
- no lightning or explosion
- Full safety equipment to protect electrical equipment when there is a problem.
Thank you very much
浏览: 3191   回复: 1
What is the expected format for entering weather underground? weather id?
August Divjak
更新时间 2022-01-07 23:41:01 UTC
For
KFLORLAN660 Id in weather underground app,. The setup continues to state that I should supply a valid I'd code.  I've tried many different ways with no luck.  Can you help here?
浏览: 3115   回复: 1
No wifi connection
lawnguy4
更新时间 2022-01-10 05:16:03 UTC
Just got the Sprite 6 controller and it won't connect to Wi-Fi. I have a mesh wi-fi system and the controller has full bars but it just refuses to connect. I reset it a couple times , I  unplugged and plugged it back in , I tried deleting the app and doing it again and still no luck. I just keep getting an error saying ''Action control parameter missing or value is empty'' no clue what that means. Can anyone give me some advice on what else I can possibly do to make this work.. Thank you.
浏览: 2819   回复: 1
Netro is watering at 25F because it is misinterpreted weather
Ben Aggus
更新时间 2022-01-11 12:15:06 UTC
I had to cancel watering because it’s 25F this morning. It’s because the weather is misinterpreted. The forecast today is 58/34, but that means it will be 34 for tonight’s low. Last night’s low was 25 and the Netro should look at that number for watering this morning.
浏览: 3320   回复: 1
Sensor sending wrong data
Mick Faulks
更新时间 2022-01-14 06:49:41 UTC
Hi have my whisperer installed in a garden bed, it saying 0% moisture when the soil is quite wet and it is saying temp is 200 C up to 380 C I have reset it many times but continues to give these readings.
浏览: 3250   回复: 1
Jamie Campbell
更新时间 2022-01-16 22:09:35 UTC
Every time I go to login to the app, it crashes back to the iOS Home Screen. I’m running iOS 15.1.1 on an iPhone mini. I have tried deleting and reinstalling the app several times and the app works until I put my login details in, then it crashes.
浏览: 3046   回复: 2
Pixie smart timer battery not charging
Becky Aquino
更新时间 2022-01-23 00:57:20 UTC
Anyone have an issue with the pixie battery not charging from the unit using solar? My battery level is down to 19% and I live in Hawaii, lots of sun. Not sure if I did something wrong.
浏览: 2988   回复: 1
Programación
Helidoro Sánchez
更新时间 2022-01-23 09:55:54 UTC
浏览: 2948   回复: 1
Wessam Elbaz
更新时间 2022-01-26 21:28:38 UTC
浏览: 2733   回复: 1
Viento
Helidoro Sánchez
更新时间 2022-01-27 20:48:39 UTC
Gracias,
浏览: 3092   回复: 2
Marcos De Maria
更新时间 2022-02-07 19:44:16 UTC
Buenas ! No logro que prenda el riego .. si ven en la
Foto tengo una electro válvula roja .. para un lado funciona el llenado de la pileta , para el otro el riego x manguera .. en 0 Que es donde está en la foto debería darle la orden la computadora para que encienda la bomba y empiece a regar q estoy haciendo mal ??
浏览: 2994   回复: 2
I can’t seem to be able to reschedule my program
cmeital
更新时间 2022-02-07 21:51:50 UTC
浏览: 2611   回复: 1
Adding a Whisperer to more than one zone
rgbelli
更新时间 2022-02-08 23:01:43 UTC
I currently have one Whisperer for a single zone that covers lawn. As I have 4 lawn zones can I add the lawn Whsiperer to all 4 zones?
浏览: 2898   回复: 1
Whisper temperature and solar data availability to ITTT
August Divjak
更新时间 2022-02-11 18:31:44 UTC
Whisper temperature and solar data availability to ITTT or another application so I can trigger events on Leviton system.
浏览: 2919   回复: 1
Vieri Verze
更新时间 2022-02-12 10:09:09 UTC
浏览: 2982   回复: 1
Netro Whisperer Nuevo 2 dias y no enciende…
Quim Retbin
更新时间 2022-02-14 20:51:24 UTC
Hola, compre el Netro whisperer y con 2 dias al menos 4 h al sol y siempre la luz roja es normal esto?
Pone que 1h es 2 a 3 dias y aun no ha encendido ningun dis y tampoco lo he podido configurar ni nada.
浏览: 3270   回复: 1
whisperer off almost 1 month
更新时间 2022-02-16 17:01:49 UTC
seems that whisperer didnt collect data for almost one month!!, this is due to battery? we are in winter but it’s installed on a sunny place!! and app did no send alerts when this happens!!?
浏览: 3404   回复: 1
Duane Smith
更新时间 2022-02-16 21:58:22 UTC
Good Afternoon Everyone,
Duane
浏览: 3018   回复: 1
