How many rain sensors?
Roland Pircher
更新时间 2022-09-01 17:53:32 UTC
浏览: 2742   回复: 1
Two zones running at the same time
Jesse Sanchez
更新时间 2022-09-02 03:52:13 UTC
Anyone running into an issue of having two zones run at the same time when doing a manual run?
浏览: 2768   回复: 1
Karen Thompson
更新时间 2022-09-02 15:15:20 UTC
浏览: 3123   回复: 1
更新时间 2022-09-05 21:41:34 UTC
KVACHEST132
浏览: 3048   回复: 1
更新时间 2022-09-07 05:47:06 UTC
May you check it?
浏览: 3159   回复: 1
更新时间 2022-09-07 21:08:59 UTC
浏览: 3110   回复: 1
更新时间 2022-09-10 12:26:33 UTC
浏览: 2994   回复: 1
Add a manager
Tom Warren
更新时间 2022-09-10 16:36:08 UTC
浏览: 2797   回复: 2
Cannot reset Sprite
punyelroo
更新时间 2022-09-10 22:30:01 UTC
How do I fix this ?
-A
浏览: 3032   回复: 1
quick stop every watering
Lee Hill
更新时间 2022-09-11 20:34:04 UTC
浏览: 2975   回复: 1
Mulch impact on duration
John Wright
更新时间 2022-09-13 12:58:29 UTC
浏览: 2903   回复: 1
Different symbols in the app
Leon Durning
更新时间 2022-09-13 16:05:13 UTC
What does the ! mean?
浏览: 2907   回复: 1
Not watering
jons
更新时间 2022-09-16 09:37:00 UTC
It shows watering, but it is not?
浏览: 2823   回复: 1
Fernando Cantu
更新时间 2022-09-19 03:37:26 UTC
浏览: 3341   回复: 2
Watering during a restriction
Valeria Dp
更新时间 2022-09-20 20:26:21 UTC
Tonight at 2.30 my netro start to watering. I had to stop it starting a manual program and stop it because in the app there was no watering sign.
Then I put a restriction for 3 days and around noon netro starts to watering again. There was a lost wifi signal for a minute cause by a voltage drop.
Is it normal?
浏览: 2888   回复: 1
Ananth
更新时间 2022-09-21 12:25:49 UTC
 How do i change this?
lot of water being wasted.
Ananth Bandla
浏览: 3510   回复: 2
Sprite-6
Rockhead413
更新时间 2022-09-26 18:04:30 UTC
Vincent Devlahovich
浏览: 2911   回复: 1
Irrigation program,
Rosario Russo
更新时间 2022-09-27 10:58:58 UTC
Rosario
浏览: 2873   回复: 1
Rosario Russo
更新时间 2022-09-27 11:06:57 UTC
浏览: 2894   回复: 1
Rick Miller
更新时间 2022-09-29 23:49:53 UTC
浏览: 2932   回复: 1
