stefano banfi gaslini
更新时间 2020-03-18 15:16:20
hi,
it was particularly dry.
indicates that it is 98% wet.
what is wrong?
tnks
best regards
stefano
浏览: 3358   回复: 1
Instalación wifi
Eduardo Pariente
更新时间 2020-03-20 16:15:47
Good afternoon.
 I have problems because I don't recognize the wifi.  I'll explain. First I connect by wifi to netro and it does not give me any problems.  But when I go back to the next screen to connect the mobile to the wifi and the wifi from home no longer appears. He's gone. And I can't continue with the installation.
浏览: 3396   回复: 1
Yohan
更新时间 2020-03-22 00:49:00
浏览: 3409   回复: 1
Smart scheduling problem
更新时间 2020-03-23 19:15:51
This is my set up.
1) why this happened?
浏览: 3736   回复: 1
Giacomo
更新时间 2020-03-24 14:44:34
Thanks in advance
浏览: 3905   回复: 1
J H
更新时间 2020-03-24 21:16:47
浏览: 3211   回复: 1
Garden
Steven Carnie
更新时间 2020-03-26 14:53:02
浏览: 4442   回复: 1
Max V
更新时间 2020-03-27 18:52:10
Hi everyone!
浏览: 4225   回复: 1
duerson
更新时间 2020-03-27 20:59:20
浏览: 3409   回复: 1
2 or more zone at same time
Mirko Paganelli
更新时间 2020-03-28 15:32:05
浏览: 3341   回复: 1
Run Netro in one zone now
Stan Bumgarner
更新时间 2020-03-28 20:15:35
Stan
浏览: 3205   回复: 1
Rain adjustment
Arvind Ramanadham
更新时间 2020-03-31 19:10:38
浏览: 3614   回复: 1
Dark Sky
Vardhan Rajkumar
更新时间 2020-04-01 21:55:47
浏览: 3727   回复: 2
Installing Pixie
kristinsavage
更新时间 2020-04-03 21:25:20
I am trying to install my Netro Pixie and the vacuum breaker is blocking the filter on the Pixie. Any suggestions?
浏览: 3474   回复: 1
power adaptor
更新时间 2020-04-04 14:39:25
just received a Netro Sprite controller 12 sone without power adapter
I am in Rome , Italy
We have 240 volts energy supply
what adapter have i to buy ?
thanks
paolo
浏览: 3684   回复: 2
Joe Ryan
更新时间 2020-04-05 17:48:32
浏览: 3557   回复: 1
Casey S
更新时间 2020-04-05 19:41:30
浏览: 3584   回复: 1
Home Assistant integration
Casey S
更新时间 2020-04-05 19:46:53
浏览: 3767   回复: 2
Host mode
Luca Manfrin
更新时间 2020-04-06 17:55:38
What is host mode?
浏览: 3584   回复: 1
Settings
Massimo Povolo
更新时间 2020-04-07 06:31:48
浏览: 3843   回复: 5
