Skipping skipped?
livingwater71
更新时间 2018-10-31 16:11:03 UTC
浏览: 3912   回复: 1
EPA rebate status?
Joshua Berk
更新时间 2018-11-04 07:39:58 UTC
Hi I was wondering if we could get an update on where Netro is with an EPA rebate? We're aware Netro has applied, but any word or ETA on getting certification for rebates?  Thank you
浏览: 4570   回复: 3
Water pump shutting off
Ryan Cochran
更新时间 2018-11-26 02:32:24 UTC
浏览: 4166   回复: 1
Rebekah H
更新时间 2018-11-28 04:23:43 UTC
浏览: 4115   回复: 1
Sangjin Lee
更新时间 2018-12-15 18:56:48 UTC
Thanks in advance!
浏览: 6845   回复: 1
Leak detection
Joshua Berk
更新时间 2019-01-03 15:27:07 UTC
Rachio has a new leak detection device you can install on the pipe that talks to the controller letting it know if there's water flow that shouldn't be happening. Do you guys have plans to do anything like this? Would absolutely be interested in it!
浏览: 3975   回复: 0
St. Augustine
Spencer Vaughn
更新时间 2019-01-10 03:15:53 UTC
浏览: 4747   回复: 2
Tim Cox
更新时间 2019-02-02 01:35:59 UTC
浏览: 4212   回复: 3
Nathan Anderson
更新时间 2019-02-13 03:53:31 UTC
浏览: 4181   回复: 1
Scot and Michelle Cowan
更新时间 2019-03-03 17:04:51 UTC
浏览: 4443   回复: 1
Instructions about Replacing Toro System
更新时间 2019-03-20 08:07:29 UTC
Replacing Toro system
This page lists some instructions about replacing the common types of Toro system with Netro smart watering controller.
Example 1:
Toro model gk212-04
1. Connect the 2 white wires to the C slots, one on the left and the other on the right which is now occupied by a red one.
2. Move the red wire(currently on C slot) to M slot because it is for your master valve.
3. The last step is to connect the power then you should be good to go.
Example 2:
Toro IC 8.
The first slot of your current controller is master valve which should be connected  to "M" slot of Netro. The two wires in the second slot are common wires should be connected to the 'C' slot of Netro. The last step is to connect the power then you should be good to go.
Example 3:
Toro Model 53765 6 zones
The red and white wires are the commons wires and should go to the two "C" slots in Netro Sprite controller. You do not need to connect the gray and black wires as they are the power wires for the old controller.
浏览: 5812   回复: 0
更新时间 2019-03-20 08:03:05 UTC
Replacing old system
Example 1:
I check the pictures.
OLD                 Sprite
COM                any C slot
1                     1
2                     2
3                     3
4                     4
Example 2:
Example 3:
Example 4:
Other wires are not needed.
Example 5:
浏览: 4456   回复: 0
Overriding smart waterinh
mvernia
更新时间 2019-03-17 20:46:27 UTC
浏览: 3811   回复: 1
charu
更新时间 2019-03-21 16:27:21 UTC
浏览: 3677   回复: 1
Not able to water
更新时间 2019-03-27 13:18:49 UTC
浏览: 4085   回复: 1
controller firmware
Magnus Swenson
更新时间 2019-03-27 19:55:40 UTC
Does the controller update its own firmware automatically on a specific schedule or you push out when needed?
浏览: 4267   回复: 1
windy conditions
Magnus Swenson
更新时间 2019-03-27 20:05:53 UTC
The setting for windy conditions is great.
However the zones that includes drip irrigation doesn’t get impacted by winds (since they’re often under dirt/mulch etc) usually rotors and nozzles would be impacted . Is there a way not to include in ground drip irrigation on windy conditions?
浏览: 3828   回复: 1
MAC address
Lee Hill
更新时间 2019-03-29 15:45:44 UTC
浏览: 4015   回复: 1
Smart home integration
Matt Griste
更新时间 2019-03-29 22:29:57 UTC
浏览: 4239   回复: 2
Smart Watering Basic with a schedule watering adjustment
Barry Perfect
更新时间 2019-04-13 17:00:37 UTC
If I have a zone set to Smart Watering - Basic with a schedule to come on for 30 minutes, will the smart watering adjust the duration of the watering based on the weather (say 10 minutes when it’s cool, the full 30 minutes when it is hot), or just turn it off/on based on the 5mm expected rain threshold?
Barry
浏览: 3708   回复: 1
