Simon Sollberger
更新时间 2019-06-18 20:39:36 UTC
浏览: 4616   回复: 2
Amount of Rainfall keeps changing
Swaroop Jay
更新时间 2019-06-19 02:47:10 UTC
Netro app keeps changing the amount of rainfall that we have had. Day before yesterday it rained heavily. The very next day Netro app showed that it rained 1 inch. Today it’s showing that on that same day it rained only 0.33 inch. Any idea why it keeps fluctuating for something that has already happened in the past?
浏览: 3915   回复: 1
Not enough water
Robert Arnold
更新时间 2019-06-19 03:22:58 UTC
浏览: 3752   回复: 1
GPS position
alesee COA
更新时间 2019-06-21 08:24:13 UTC
浏览: 3831   回复: 1
Start / End time
更新时间 2019-06-21 10:14:14 UTC
浏览: 3866   回复: 1
watering usage doesn't match
Sangjin Lee
更新时间 2019-06-21 22:49:22 UTC
Here is something I cannot reconcile. I am dealing with a pretty big water usage reported by the utility. It says in the month of May I used 530 GPD (gallons per day). I seem to be watering every 3 days (set by Netro).
Compared to winter months when I rarely watered the lawn due to the rainy season, it is a jump of ~ 270 GPD.
When I check the Netro app, it reports I used ~ 3.5 CCF for the month of May. 1 CCF = 748 gallons, and that translates to roughly 87 gallons per day. This is less than 1/3 of what the utility is telling me. How can this discrepancy be explained? Any ideas/tips for finding why I seem to be using this much water? Thanks in advance!
浏览: 4102   回复: 1
更新时间 2019-06-23 13:34:06 UTC
浏览: 4347   回复: 1
Jonathan B.
更新时间 2019-06-24 03:20:54 UTC
浏览: 4290   回复: 2
Yanke Liang
更新时间 2019-06-24 11:07:31 UTC
浏览: 3977   回复: 1
Restriction for specific days
更新时间 2019-06-24 18:20:32 UTC
I want to create restrictions for a set of specific days in the future.  Birthdays of family members for example. Or days that I have outdoor entertainment planned. I want to set these up long in advance (before a smart schedule has been scheduled.) How can I do this?
浏览: 4287   回复: 1
Remove whisperer
Dan Orms
更新时间 2019-06-25 16:17:24 UTC
浏览: 4142   回复: 1
Support for IFTT
Shahid Warraich
更新时间 2019-06-25 17:25:17 UTC
浏览: 3883   回复: 1
Google Home app questions- just installed my Netro Sprite!
jdonhowe
更新时间 2019-06-26 04:16:22 UTC
I just installed my Netro Sprite and am having fun investigating all the options. After some false steps, I was able to link it to my google home account. so, my questions:
1. When I go through google, do I always have to say "Okay, Google, talk to Netro Sprite", and then when Netro responds, give a command, such as "water zone 1 for five minutes". Is there any way such that I can say directly to google "water zone 1", and Netro will do it (like smart light switches)- I don't have to tell google to tell TP-link to turn on the bedroom light!
2. I know that Netro controls zones sequentially (only one on at a time). When I ask Netro (through google home) to water zone 1 for x minutes, it then asks "what else can I do for you". If I say "water zone 2 for x minutes, it looks like it immediately turns off zone 1, and turns on zone 2. So, does "what else" mean "instead of", rather than "in addition to" the first command? Is there any way to get it to recognize sequential zone commands?
3. I've renamed my zones in the Netro app (nice touch- always hated having to remember zone numbers with old controller. Is there any way for the Netro google link to recognize (like google home does with devices) the name of a zone? It would be great to say "water front lawn for five minutes" instead of having to remember which zone it is.
浏览: 4297   回复: 1
PIR sensor
Vito Favaretto
更新时间 2019-06-26 20:06:49 UTC
I always find cats dejections on my garden but I  cats are not mines. I had an idea to avoid these cats' gift, installing a PIR sensor connected to netro controller by wifi that transmit a signal to water garden at cats presence. Cats don't love water so they leave my garden very quickly.
Do you think you can build a sensor like this?
I.could be a beta tester ;)
浏览: 4061   回复: 1
Watering Times
terry
更新时间 2019-06-26 22:02:52 UTC
浏览: 3955   回复: 1
WiFi connection
Andrew
更新时间 2019-06-27 00:49:26 UTC
浏览: 3612   回复: 0
Whisper shipping
Matty B
更新时间 2019-06-30 13:31:58 UTC
I ordered a sensor and have yet to receive it. It has been well past 4 weeks.
Number is: 180404 ― May 17, 2019
What is the status of the order?
浏览: 4265   回复: 2
internet may not be available
Bruce Vermeulen
更新时间 2019-06-30 18:31:02 UTC
Bruce
浏览: 3800   回复: 0
Nipun Devlekar
更新时间 2019-07-01 01:01:18 UTC
浏览: 3696   回复: 1
Adapter in EU
Lukas2002
更新时间 2019-07-01 11:06:15 UTC
I am Lukas from the Netherlands. I have ordered a Netro sprite-6 on without a power adapter.
In the Netherlands we have 230V AC on the power grid. I am having serious trouble to find a power adapter that goes to 24V AC 800mA.
The only one I can find has an output of  24V AC 1000mA, will that be ok?
Or is there a better alternative out there?
Lukas Zwanenburg (NL)
浏览: 4284   回复: 2
