更新时间 2019-06-23 13:34:06
浏览: 4919   回复: 1
Jonathan B.
更新时间 2019-06-24 03:20:54
浏览: 4851   回复: 2
Yanke Liang
更新时间 2019-06-24 11:07:31
浏览: 4532   回复: 1
Restriction for specific days
更新时间 2019-06-24 18:20:32
I want to create restrictions for a set of specific days in the future.  Birthdays of family members for example. Or days that I have outdoor entertainment planned. I want to set these up long in advance (before a smart schedule has been scheduled.) How can I do this?
浏览: 4837   回复: 1
Remove whisperer
Dan Orms
更新时间 2019-06-25 16:17:24
浏览: 4714   回复: 1
Support for IFTT
Shahid Warraich
更新时间 2019-06-25 17:25:17
浏览: 4435   回复: 1
Google Home app questions- just installed my Netro Sprite!
jdonhowe
更新时间 2019-06-26 04:16:22
I just installed my Netro Sprite and am having fun investigating all the options. After some false steps, I was able to link it to my google home account. so, my questions:
1. When I go through google, do I always have to say "Okay, Google, talk to Netro Sprite", and then when Netro responds, give a command, such as "water zone 1 for five minutes". Is there any way such that I can say directly to google "water zone 1", and Netro will do it (like smart light switches)- I don't have to tell google to tell TP-link to turn on the bedroom light!
2. I know that Netro controls zones sequentially (only one on at a time). When I ask Netro (through google home) to water zone 1 for x minutes, it then asks "what else can I do for you". If I say "water zone 2 for x minutes, it looks like it immediately turns off zone 1, and turns on zone 2. So, does "what else" mean "instead of", rather than "in addition to" the first command? Is there any way to get it to recognize sequential zone commands?
3. I've renamed my zones in the Netro app (nice touch- always hated having to remember zone numbers with old controller. Is there any way for the Netro google link to recognize (like google home does with devices) the name of a zone? It would be great to say "water front lawn for five minutes" instead of having to remember which zone it is.
浏览: 4845   回复: 1
PIR sensor
Vito Favaretto
更新时间 2019-06-26 20:06:49
I always find cats dejections on my garden but I  cats are not mines. I had an idea to avoid these cats' gift, installing a PIR sensor connected to netro controller by wifi that transmit a signal to water garden at cats presence. Cats don't love water so they leave my garden very quickly.
Do you think you can build a sensor like this?
I.could be a beta tester ;)
浏览: 4640   回复: 1
Watering Times
terry
更新时间 2019-06-26 22:02:52
浏览: 4528   回复: 1
WiFi connection
Andrew
更新时间 2019-06-27 00:49:26
浏览: 4182   回复: 0
Whisper shipping
Matty B
更新时间 2019-06-30 13:31:58
I ordered a sensor and have yet to receive it. It has been well past 4 weeks.
Number is: 180404 ― May 17, 2019
What is the status of the order?
浏览: 4853   回复: 2
internet may not be available
Bruce Vermeulen
更新时间 2019-06-30 18:31:02
Bruce
浏览: 4356   回复: 0
Nipun Devlekar
更新时间 2019-07-01 01:01:18
浏览: 4250   回复: 1
Adapter in EU
Lukas2002
更新时间 2019-07-01 11:06:15
I am Lukas from the Netherlands. I have ordered a Netro sprite-6 on without a power adapter.
In the Netherlands we have 230V AC on the power grid. I am having serious trouble to find a power adapter that goes to 24V AC 800mA.
The only one I can find has an output of  24V AC 1000mA, will that be ok?
Or is there a better alternative out there?
Lukas Zwanenburg (NL)
浏览: 4863   回复: 2
更新时间 2019-07-01 16:32:17
浏览: 4771   回复: 1
Notifiche push
Andrea Casali
更新时间 2019-07-01 19:07:47
Ciao, è possibile ricevere delle notifiche push tutte le volte che parte l’irrigazione?
浏览: 4484   回复: 1
Rain versus no rain
Dennis G
更新时间 2019-07-03 03:27:38
浏览: 4646   回复: 1
Forecast provider for Italy
Gabriele Gianello
更新时间 2019-07-03 11:53:03
浏览: 4864   回复: 1
Smart watering
John Jessee
更新时间 2019-07-03 22:25:57
浏览: 4344   回复: 1
Saurik
更新时间 2019-07-04 07:12:42
浏览: 4512   回复: 1
