Service account
ltanase13
更新时间 2019-04-25 01:26:55
浏览: 4548   回复: 1
One sensor for multiple zones
bdcfam
更新时间 2019-05-01 01:28:20
Is there a way to assign one sensor to multiple zones?
浏览: 7073   回复: 2
Connecting Hunter PVG-Valves
John Mayer
更新时间 2019-05-01 15:57:37
I am trying to connect my Hunter PVG 101 GB valves to my new Metro Sprite.
I haven't installed a watering System before so I am quite a newbie here.
I have managed to set my Sprite up. But my valves aren't working.
I have double checked my wires. No issue there. As I am living in Germany I have bought my own power supply. It's this one: INNOVATE LED Trafo ECO 24 Volt/DC, 0-50W - LED Treiber - Transformator - Netzteil - Driver (24V - 50W) https://www.amazon.de/dp/B01AALEYR8/ref=cm_sw_r_cp_apa_i_LgCYCb2PT86Y9
Are there any recommendations, what I could do wrong?
Thanks so much,
浏览: 4985   回复: 2
Graphs
Jim Bethea
更新时间 2019-05-04 11:25:22
浏览: 4358   回复: 1
John Locke
更新时间 2019-05-05 14:16:12
浏览: 4601   回复: 1
Henry
更新时间 2019-05-06 19:40:59
same issue...
so what to do with it?
浏览: 4694   回复: 2
is the Pixie faucet joint (both in and out) GHT (Garden Hose Thread) or NPT (National Pipe Thread)
Oliver Pettit
更新时间 2019-05-09 01:33:23
Could you please confirm if the Pixie faucet joint is GHT (garden hose thread) or is it NPT (National Pipe Thread)?
I'm looking for adapters in Australia to use this unit and its unclear what the size/type the faucet is.
浏览: 4900   回复: 1
Problemi con Google home
Max Point
更新时间 2019-05-12 08:36:40
Massimo
浏览: 4493   回复: 1
更新时间 2019-05-14 07:01:36
浏览: 5190   回复: 2
Manual mode fail to shut off
更新时间 2019-05-16 02:05:13
浏览: 4710   回复: 1
Whisperer stopped working
Pelle Fisk
更新时间 2019-05-17 13:30:13
浏览: 5218   回复: 2
Hot weather algorithm
Joshua Berk
更新时间 2019-05-17 16:15:51
浏览: 4836   回复: 2
Steven V
更新时间 2019-05-18 13:08:55
浏览: 4386   回复: 1
David Claridge
更新时间 2019-05-18 13:21:53
浏览: 4427   回复: 1
Dennis N
更新时间 2019-05-18 17:52:30
浏览: 4359   回复: 1
Roianne Cox
更新时间 2019-05-19 13:52:50
浏览: 4314   回复: 1
jpmeyer81
更新时间 2019-05-19 15:04:11
浏览: 4734   回复: 1
Manually skip next watering
Randy Ziffer
更新时间 2019-05-19 16:47:13
浏览: 4581   回复: 2
Remote Access?
Oliver Pettit
更新时间 2019-05-22 01:53:35
Oliver
浏览: 4910   回复: 1
Can't see answers to questions
Stan Bumgarner
更新时间 2019-05-23 00:30:01
I can see the question and can see that someone has answered it. How do I see the answer?
Stan
浏览: 4429   回复: 1
