Suggestion: Sunrise smart watering
Mark S
更新时间 2019-04-15 13:39:43 UTC
I think Rachio adjusts the watering schedule with sunrise to have all zones completed as the sun is coming up. Is this something you intend to add? I think this will come in handy with the heat of summer.
浏览: 3886   回复: 1
更新时间 2019-04-20 12:21:46 UTC
Mr Bad Example
浏览: 4080   回复: 1
Weather Company API- Revenue stream for Netro
更新时间 2019-04-20 12:58:20 UTC
It is my understanding that you could restore our ability to pull data into netro from our individual weather stations. This would require paying for the API, which you could mark up 20% and offer a paid option to netro clients. $3.99 a year, for example, would be totally worth it to get accurate information to my sprinkler controller. As I have outlined in a previous post, dark sky has proven to be wildly inaccurate. It's Miss estimates rainfall by at least 50%, on average, and is within three degrees plus or minus on high temperature only about 50% of the time.
浏览: 4725   回复: 4
John Mac
更新时间 2019-04-22 23:42:30 UTC
浏览: 3664   回复: 1
Alexa
Emilio Maione
更新时间 2019-04-24 06:50:56 UTC
浏览: 3884   回复: 1
Answers?
Howard Blankenship
更新时间 2019-04-24 14:46:54 UTC
浏览: 3561   回复: 1
Service account
ltanase13
更新时间 2019-04-25 01:26:55 UTC
浏览: 3877   回复: 1
One sensor for multiple zones
bdcfam
更新时间 2019-05-01 01:28:20 UTC
Is there a way to assign one sensor to multiple zones?
浏览: 6340   回复: 2
Connecting Hunter PVG-Valves
John Mayer
更新时间 2019-05-01 15:57:37 UTC
I am trying to connect my Hunter PVG 101 GB valves to my new Metro Sprite.
I haven't installed a watering System before so I am quite a newbie here.
I have managed to set my Sprite up. But my valves aren't working.
I have double checked my wires. No issue there. As I am living in Germany I have bought my own power supply. It's this one: INNOVATE LED Trafo ECO 24 Volt/DC, 0-50W - LED Treiber - Transformator - Netzteil - Driver (24V - 50W) https://www.amazon.de/dp/B01AALEYR8/ref=cm_sw_r_cp_apa_i_LgCYCb2PT86Y9
Are there any recommendations, what I could do wrong?
Thanks so much,
浏览: 4292   回复: 2
Graphs
Jim Bethea
更新时间 2019-05-04 11:25:22 UTC
浏览: 3692   回复: 1
John Locke
更新时间 2019-05-05 14:16:12 UTC
浏览: 3931   回复: 1
Henry
更新时间 2019-05-06 19:40:59 UTC
same issue...
so what to do with it?
浏览: 4026   回复: 2
is the Pixie faucet joint (both in and out) GHT (Garden Hose Thread) or NPT (National Pipe Thread)
Oliver Pettit
更新时间 2019-05-09 01:33:23 UTC
Could you please confirm if the Pixie faucet joint is GHT (garden hose thread) or is it NPT (National Pipe Thread)?
I'm looking for adapters in Australia to use this unit and its unclear what the size/type the faucet is.
浏览: 4216   回复: 1
Problemi con Google home
Max Point
更新时间 2019-05-12 08:36:40 UTC
Massimo
浏览: 3819   回复: 1
更新时间 2019-05-14 07:01:36 UTC
浏览: 4507   回复: 2
Manual mode fail to shut off
更新时间 2019-05-16 02:05:13 UTC
浏览: 4004   回复: 1
Whisperer stopped working
Pelle Fisk
更新时间 2019-05-17 13:30:13 UTC
浏览: 4460   回复: 2
Hot weather algorithm
Joshua Berk
更新时间 2019-05-17 16:15:51 UTC
浏览: 4155   回复: 2
Steven V
更新时间 2019-05-18 13:08:55 UTC
浏览: 3709   回复: 1
David Claridge
更新时间 2019-05-18 13:21:53 UTC
浏览: 3740   回复: 1
