更新时间 2025-05-09 12:29:14 UTC
浏览: 460   回复: 3
Zones not turning on
Neil ONeill
更新时间 2025-05-09 12:41:28 UTC
浏览: 420   回复: 1
Protecting whisperer from dog
更新时间 2025-05-09 17:54:44 UTC
浏览: 352   回复: 0
Whisperer 2 temperature?
Brett Rabe
更新时间 2025-05-09 19:07:46 UTC
Thoughts?
浏览: 440   回复: 1
Will not connect
Rick VanHooser
更新时间 2025-05-10 16:15:01 UTC
浏览: 469   回复: 2
Kata Cserni
更新时间 2025-05-13 15:32:11 UTC
  1. How can I set an irrigation schedule without WiFi? I have a rental house that is not occupied ( no Internet service) , but I would like to create an irrigation schedule. I app allows me to connect for test run, but not to set new schedule.
浏览: 421   回复: 1
Panda88
更新时间 2025-05-15 18:20:45 UTC
浏览: 374   回复: 1
Paolo S
更新时间 2025-05-15 20:41:08 UTC
How can I do?
浏览: 412   回复: 1
更新时间 2025-05-16 12:40:39 UTC
浏览: 355   回复: 1
Whisper Gen 2 update firmware
Phil Middleton
更新时间 2025-05-16 14:28:46 UTC
浏览: 381   回复: 1
Transformer replacement
zoompj@gmail.com
更新时间 2025-05-18 18:43:54 UTC
I have Netro 6
Please help
浏览: 358   回复: 1
Minh Thu Nguyen
更新时间 2025-05-19 08:42:52 UTC
Dear Netro Support Team,
Best regards,
Minh Thu, Nguyen
浏览: 377   回复: 1
Smart Zones are random
Dave H
更新时间 2025-05-19 15:27:46 UTC
Sprite-12
and/or
浏览: 384   回复: 1
Refurbished netro controller
drylake
更新时间 2025-05-23 23:37:47 UTC
浏览: 229   回复: 1
Battery Issue - Netro Stream
K L
更新时间 2025-05-25 03:09:56 UTC
Dear Fellows,
Device Details:
  • Hardware : Netro Stream 1.0
  • Firmware: 1.0.0
Best regards,
Kelvin
浏览: 230   回复: 1
Mikael Hammarin
更新时间 2025-05-26 17:18:52 UTC
Suggestion:
浏览: 212   回复: 1
New Sprite Owner
Bryant Bustamante
更新时间 2025-05-26 22:46:01 UTC
浏览: 234   回复: 1
Water consumption
cwo
更新时间 2025-06-01 19:51:34 UTC
浏览: 91   回复: 0
Alexa with two Pizie
Stefano Giorgi
更新时间 2025-06-03 16:11:11 UTC
How can I fix this issue?
浏览: 32   回复: 0
Zone not coming on
Herbert Bailey
更新时间 2020-06-15 13:00:35 UTC
浏览: 3206   回复: 1
