Zone watering while disabled
Brian Paternostro Paternostro
更新时间 2024-07-31 10:10:11 UTC
I am doing yard work to 2 of my 3 zones right now and have the whole system disabled for several days as many heads are disconnected.  Woke up a 5am to have zone 3 on and spraying water everywhere for 20 minutes.
How is this possible? Why do you not update your softwar?
浏览: 3609   回复: 2
2 hub-1 in my house
Troy Guinn
更新时间 2024-08-09 00:15:52 UTC
I have 2 pixe devices and 2 hubs. I have 1 hub and pixie working fine. When I added the 2nd hub it does not show up in the app and therefore cannot add the 2nd pixie what am I doing wrong
浏览: 3461   回复: 1
deleting plant sensor
David Ridgwell
更新时间 2024-08-10 01:31:44 UTC
deleting plant sensor??
浏览: 3483   回复: 1
Terminal 1 not working
Morgans_Home
更新时间 2024-08-12 01:27:03 UTC
浏览: 3194   回复: 1
Smart watering very stupid
Ruth Wengert
更新时间 2024-08-13 14:22:33 UTC
浏览: 3219   回复: 1
Van Klaveren Patrick
更新时间 2024-08-15 10:04:53 UTC
浏览: 3162   回复: 1
Riego
Felipe Martinez Cuadrado
更新时间 2024-08-16 21:16:23 UTC
He instalado el programador y de vez en cuando salta una de las zonas
浏览: 3415   回复: 1
1 valve works, two don't
Phil Rubin
更新时间 2024-08-17 21:52:30 UTC
浏览: 3274   回复: 1
problematiche app
Giampaolo Mariani
更新时间 2024-08-20 08:16:25 UTC
浏览: 3249   回复: 1
Ac adaptor
Cisco -
更新时间 2024-08-24 21:45:58 UTC
浏览: 3061   回复: 1
Replace controller
paul.robinson@bigbend.net
更新时间 2024-08-24 22:53:15 UTC
浏览: 3097   回复: 1
Wunderground
PPL
更新时间 2024-09-02 17:42:25 UTC
浏览: 3055   回复: 1
Tie the irrigation of two lines on the same garden
Francesco
更新时间 2024-09-04 07:59:17 UTC
I have two irrigation lines on the same garden, is there any setting that would allow these two areas to be “tied together” such that they irrigate on the same day (session)? (Obviously first one line and then the other).
浏览: 3419   回复: 1
Discrepancia APP y WEB
JM del Amo
更新时间 2024-09-07 13:06:53 UTC
浏览: 3080   回复: 1
Pierluigi Cilli
更新时间 2024-09-08 07:29:59 UTC
浏览: 3176   回复: 1
Broken whisperer sensor
Jesús López
更新时间 2024-09-09 16:19:33 UTC
Hi everyone!
浏览: 3270   回复: 2
Smart watering not working
更新时间 2024-09-10 16:17:51 UTC
浏览: 3075   回复: 1
Sensor
Kathleen Hamilton
更新时间 2024-09-11 19:43:50 UTC
浏览: 3134   回复: 1
Thomas Murphy
更新时间 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
浏览: 3022   回复: 1
Zone 1 not watering
11807GFT
更新时间 2024-09-24 23:25:59 UTC
浏览: 3024   回复: 1
