更新时间 2019-09-17 12:12:15 UTC
浏览: 4072   回复: 1
Unit measurements
Homestead One
更新时间 2019-09-17 20:29:09 UTC
浏览: 3792   回复: 1
Schedule setup
Rich Christenson
更新时间 2019-09-21 14:51:31 UTC
浏览: 3777   回复: 1
Whisperer seems wrong
Tim Foster
更新时间 2019-09-22 15:02:12 UTC
I only got my system delivered yesterday, so this could be something that I doing wrong, I have one whisperer in the back garden and one in the front. I live in Merida Yucatan and so it's hot all the time. The whisperer in the back is in direct sunlight most of the day yet it's reporting the temperature as 24. The one in the front is shaded by the house yet that is reporting 33. Both seem to be reporting incorrect moisture levels in both the topsoil and subsoil. Yucatán drains through stone to underground water sources so I would expect both topsoil and subsoil to be showing very arid.
Can anyone advise?
浏览: 3956   回复: 1
Tony D.
更新时间 2019-09-24 21:08:17 UTC
Hello everybody,
浏览: 4018   回复: 1
Ip address
Kris Y
更新时间 2019-09-25 20:13:08 UTC
浏览: 3857   回复: 1
Solid white light after install - HELP
Carlos Oliveira
更新时间 2019-09-25 20:29:08 UTC
I have just replaced a Rain bird image 6 by the Netro Sprite and I am using it's power supply.
The problem is that once I connect it after first install it gets to solid white light. I press reset shortly or even for 8 seconds but nothing changes.
Can someone help me ?
浏览: 4017   回复: 1
Cold winter season and whisperer ?
Yves Desrosiers
更新时间 2019-09-26 11:12:56 UTC
We have to take back inside our home the whisperer when the cold season is back I guess ? At what  exterior tempeture we should do this ?
浏览: 5215   回复: 3
hanz.blatt@gmail.com
更新时间 2019-09-29 13:59:02 UTC
浏览: 7032   回复: 2
Nguyễn Vinh
更新时间 2019-09-30 06:46:55 UTC
浏览: 4020   回复: 2
sqwu
更新时间 2019-09-30 13:51:09 UTC
浏览: 3920   回复: 1
Installation Direct to pump
Tim Foster
更新时间 2019-10-03 11:23:32 UTC
I have the following:
浏览: 4280   回复: 2
Weird watering plan
Manuel Roca
更新时间 2019-10-12 11:34:00 UTC
浏览: 3731   回复: 1
Brian Hobbs
更新时间 2019-10-15 01:58:49 UTC
浏览: 3813   回复: 1
Sangjin Lee
更新时间 2019-10-17 03:41:11 UTC
浏览: 4023   回复: 1
What about blowout?
Burghardi
更新时间 2019-10-18 02:06:15 UTC
Why doesn’t this one?
浏览: 3903   回复: 2
Riego netro para tepes
Manuel C
更新时间 2019-10-23 09:36:27 UTC
Hola,
浏览: 4584   回复: 1
Daylight savings
Craig Neidle
更新时间 2019-11-13 18:34:27 UTC
Haow can i change this?
浏览: 4057   回复: 1
Manuel Roca
更新时间 2019-11-22 17:20:29 UTC
This is an easy question
浏览: 3875   回复: 2
Black Friday
John Mayer
更新时间 2019-11-22 10:40:22 UTC
Hello Netro, will you have a black Friday offer?
浏览: 6711   回复: 1
