Netro app on google home
Danilo
更新时间 2020-04-11 10:07:58 UTC
Thanks for your support.
浏览: 3427   回复: 1
Brett Lilly
更新时间 2020-04-13 18:42:28 UTC
浏览: 3559   回复: 1
Faucet Connector Broke
Larry Griggers
更新时间 2020-04-14 18:49:27 UTC
I was having difficulty getting a leakproof seal when attaching my Smart Hose Faucet Timer (Pixie-1) to my new faucet. I finally was able to tighten it tight enough not to leak, but after a week, it broke and popped off. It is probably under warranty, but is there somewhere I can buy a new connector and repair it myself?
浏览: 3539   回复: 1
Luca Manfrin
更新时间 2020-04-16 07:47:25 UTC
Thank you for your support
浏览: 3605   回复: 2
Luca Manfrin
更新时间 2020-04-16 10:23:31 UTC
thank you
浏览: 3669   回复: 1
Range of whisperer
Fraco
更新时间 2020-04-16 19:35:32 UTC
Is there a maximum distance I can place the whisperer(s) in the garden. Largest distance it should cover is approx. 30 mtrs.
The sprite probably will be placed inside.
浏览: 3607   回复: 1
Which Alexa app?
jbart65
更新时间 2020-04-16 20:00:55 UTC
Jeffry
浏览: 3500   回复: 1
Max V
更新时间 2020-04-17 09:46:19 UTC
浏览: 3632   回复: 1
Keep Connected option
jbart65
更新时间 2020-04-17 17:38:10 UTC
The particulars:
浏览: 3503   回复: 1
Forecast vs Expectation
Arvind Ramanadham
更新时间 2020-04-17 18:25:49 UTC
浏览: 3839   回复: 1
Mixed Plant Zone
Rich Keith
更新时间 2020-04-18 23:36:39 UTC
浏览: 3432   回复: 1
Netro-Community using App
Lou Infeld
更新时间 2020-04-19 13:46:12 UTC
浏览: 4310   回复: 1
Pixie Leaks
Rich Keith
更新时间 2020-04-19 17:18:48 UTC
浏览: 3505   回复: 1
How protect Netro Sprite
Stefano Carucci
更新时间 2020-04-21 09:14:57 UTC
I need to install the Netro Sprite in a tool shed covered by tiles and closed only on three sides that I have in the garden (L 2mt, W 1.5mt, H 1.8mt).
I would like to know if, to protect it from humidity, dust and insects, I can install it in a box like this:
https://www.amazon.com/Fielect-Transparent-Switchboard-Distribution-115x90x50mm/dp/B07ZR2HN5B/ref=sr_1_17?dchild=1&keywords=transparent%2BDistribution%2Bbox&qid=1587458726&rnid=2941120011&s=hi&sr=1-17&th=1
and if this box can decrease the reception of the wifi signal.
浏览: 3396   回复: 1
Smart watering at wrong time
Joakim Björn
更新时间 2020-04-21 19:55:37 UTC
Hello!
浏览: 3342   回复: 1
google home not connected
maxtrash
更新时间 2020-04-21 23:01:57 UTC
what could be going on?
浏览: 3485   回复: 2
Best sync option?
jbart65
更新时间 2020-04-22 02:56:17 UTC
浏览: 3488   回复: 1
Whisperer ans sprite zone
lekter
更新时间 2020-04-23 14:40:17 UTC
When i install the whisperer sensor i can’t choose a zone. The installation begin without possibilities to choose.
The sensor is ok but it is not paires dithyrambiques a zone.
how i can do please ?
I leave un France
浏览: 3508   回复: 1
Gian Piero Pepino
更新时间 2020-04-25 09:23:06 UTC
Gian Piero
浏览: 3491   回复: 1
Plant Sensor
Ntenaive
更新时间 2020-04-25 21:56:51 UTC
浏览: 3801   回复: 2
