Dark Sky
Vardhan Rajkumar
更新时间 2020-04-01 21:55:47 UTC
浏览: 3909   回复: 2
Installing Pixie
kristinsavage
更新时间 2020-04-03 21:25:20 UTC
I am trying to install my Netro Pixie and the vacuum breaker is blocking the filter on the Pixie. Any suggestions?
浏览: 3664   回复: 1
power adaptor
更新时间 2020-04-04 14:39:25 UTC
just received a Netro Sprite controller 12 sone without power adapter
I am in Rome , Italy
We have 240 volts energy supply
what adapter have i to buy ?
thanks
paolo
浏览: 3867   回复: 2
Joe Ryan
更新时间 2020-04-05 17:48:32 UTC
浏览: 3740   回复: 1
Casey S
更新时间 2020-04-05 19:41:30 UTC
浏览: 3774   回复: 1
Home Assistant integration
Casey S
更新时间 2020-04-05 19:46:53 UTC
浏览: 3961   回复: 2
Host mode
Luca Manfrin
更新时间 2020-04-06 17:55:38 UTC
What is host mode?
浏览: 3767   回复: 1
Settings
Massimo Povolo
更新时间 2020-04-07 06:31:48 UTC
浏览: 4040   回复: 5
Luca Manfrin
更新时间 2020-04-07 09:19:37 UTC
浏览: 3601   回复: 1
Luca Manfrin
更新时间 2020-04-07 09:22:40 UTC
浏览: 3705   回复: 1
Luca Manfrin
更新时间 2020-04-07 09:28:22 UTC
浏览: 3696   回复: 1
Luca Manfrin
更新时间 2020-04-07 09:33:03 UTC
浏览: 3532   回复: 1
Irrigation time of 0 minutes. then?
Luca Manfrin
更新时间 2020-04-07 09:37:54 UTC
What's the point option to set the irrigation time at 0 minutes in manual execution?
It would be more useful a 30 seconds run for testing the valves.
浏览: 3710   回复: 1
Luca Manfrin
更新时间 2020-04-07 10:07:29 UTC
-SKIP FOR TODAY
浏览: 3548   回复: 1
Irrigation time striketrough
Luca Manfrin
更新时间 2020-04-07 12:34:22 UTC
thank you
浏览: 3543   回复: 1
Seb Cruzer
更新时间 2020-04-07 15:03:43 UTC
hello,
Please help!
浏览: 3798   回复: 2
Power adapter - eu
David B.
更新时间 2020-04-08 13:43:20 UTC
I have a netro sprite with an original power adapter.
How ca i connet this to my 220/230 Volt energynet in Austria pls?
A normal Adapter will not work since i have to tansform volt and ampere to 800ma and 110volt as far as i could find informations.
Kind regards david
浏览: 3725   回复: 1
Resetting Netro Whisperer
Patrick
更新时间 2020-04-09 19:34:52 UTC
浏览: 4930   回复: 1
Incorrect weather conditions
Andrea Merito
更新时间 2020-04-09 20:33:11 UTC
as the state / province is changed because Madrid is specified instead of Catania, consequently the weather is incorrect.
浏览: 3651   回复: 1
Luca Manfrin
更新时间 2020-04-10 11:43:03 UTC
浏览: 3976   回复: 2
