Claude Bedarride
更新时间 2020-02-29 14:28:34 UTC
浏览: 3429   回复: 1
Watering stops after 5 mins
D String
更新时间 2020-02-29 17:22:32 UTC
浏览: 3498   回复: 1
Distance between controller and solenoid valves
Steve Cary
更新时间 2020-03-01 14:42:55 UTC
My controller will be about 20 meters from the solenoids.  What size cable do I need to make this work? Thankyou!!
浏览: 3551   回复: 1
Carlo D'Ippolito
更新时间 2020-03-01 14:55:14 UTC
Waiting for your feedback.
Kind regards
浏览: 4079   回复: 1
Is it working correctly? 0v test multimeter
yodiego
更新时间 2020-03-07 12:14:59 UTC
Hi good morning,
I’m making the first installation and I see the valves don’t open when I tested it, so I test the connections with a multi-meter and sometimes it gives 24v and sometimes 0.
The last 10 tries it gives 0. I changed the cables and I now I test directly the controller connections and keep giving me 0.
I’m using the manual watering to make the tests.
Thank you for your help.
浏览: 3562   回复: 1
alexa & pixie
stefano banfi gaslini
更新时间 2020-03-11 14:30:37 UTC
hi,
TNKS
best regards
stefano
浏览: 3462   回复: 1
Benedetto
更新时间 2020-03-11 14:44:38 UTC
Thanks for the support
Br
BG
浏览: 3650   回复: 1
Sprinkler is on during rain
Wahid Ameni
更新时间 2020-03-14 00:12:38 UTC
浏览: 3620   回复: 1
Delivering term please
yodiego
更新时间 2020-03-14 18:08:21 UTC
浏览: 3295   回复: 1
Whisperer issue
Saul Perez
更新时间 2020-03-15 19:07:50 UTC
浏览: 3540   回复: 1
Javier Palomino
更新时间 2020-03-18 02:11:35 UTC
浏览: 3430   回复: 1
更新时间 2020-03-18 15:16:20 UTC
hi,
it was particularly dry.
indicates that it is 98% wet.
what is wrong?
tnks
best regards
stefano
浏览: 3573   回复: 1
Instalación wifi
Eduardo Pariente
更新时间 2020-03-20 16:15:47 UTC
Good afternoon.
 I have problems because I don't recognize the wifi.  I'll explain. First I connect by wifi to netro and it does not give me any problems.  But when I go back to the next screen to connect the mobile to the wifi and the wifi from home no longer appears. He's gone. And I can't continue with the installation.
浏览: 3616   回复: 1
Yohan
更新时间 2020-03-22 00:49:00 UTC
浏览: 3617   回复: 1
Smart scheduling problem
更新时间 2020-03-23 19:15:51 UTC
This is my set up.
1) why this happened?
浏览: 3952   回复: 1
Giacomo
更新时间 2020-03-24 14:44:34 UTC
Thanks in advance
浏览: 4124   回复: 1
J H
更新时间 2020-03-24 21:16:47 UTC
浏览: 3433   回复: 1
Garden
Steven Carnie
更新时间 2020-03-26 14:53:02 UTC
浏览: 4664   回复: 1
Max V
更新时间 2020-03-27 18:52:10 UTC
Hi everyone!
浏览: 4444   回复: 1
duerson
更新时间 2020-03-27 20:59:20 UTC
浏览: 3628   回复: 1
