Master valve
Sasha Obradovic
更新时间 2020-05-07 20:56:46 UTC
浏览: 3782   回复: 1
alnavasa
更新时间 2020-05-07 21:49:17 UTC
Feature request:
浏览: 3763   回复: 2
alnavasa
更新时间 2020-05-07 21:51:54 UTC
浏览: 3637   回复: 1
Kevin Tung
更新时间 2020-05-07 21:55:00 UTC
浏览: 3362   回复: 1
Andrea Merito
更新时间 2020-05-08 07:20:50 UTC
hello,
Andrea
浏览: 3488   回复: 1
Suited for exterio?
Joan Peiro
更新时间 2020-05-09 01:50:15 UTC
浏览: 3698   回复: 2
2 different water sources
Carlos Oliveira
更新时间 2020-05-09 14:51:27 UTC
I have the netro connected to one water source.
Now I am going to install a vertical garden with very low flow and I want the source of water to be a different one from the main source for the garden.
Is there a way I can connect it as an independent solenoide valve that doesn't need to have the master turned on ?
Carlos
浏览: 3726   回复: 1
Pixie Pending
Rich Keith
更新时间 2020-05-09 19:07:11 UTC
浏览: 3425   回复: 2
Chen Li
更新时间 2020-05-10 05:45:08 UTC
浏览: 3393   回复: 1
Unit system
Andrea DiPi
更新时间 2020-05-10 08:11:33 UTC
Gooooddddmoooooorning!
Here where we are!!! Torino - Cincinnati - Alice Sping - Skagen - Macao - ......
Is it possible set the app whit a unit as metric or imperial or...Mars?!? It is very boring that some parameters are in metric an other in sqft x ex.
浏览: 3850   回复: 1
Smart Watering Adjustment
Tarudro
更新时间 2020-05-11 20:56:22 UTC
Hi Guys,
Kind regards & stay healthy,
Lukas
浏览: 3789   回复: 2
where is the rst button
Jennml
更新时间 2020-05-12 18:00:51 UTC
浏览: 3457   回复: 1
Default rain settings
jbart65
更新时间 2020-05-12 21:31:24 UTC
浏览: 3699   回复: 1
hedges
Andrea Colombelli
更新时间 2020-05-14 19:45:52 UTC
浏览: 3527   回复: 1
No 2.4GHz wifi
Carlos Oliveira
更新时间 2020-05-16 11:29:24 UTC
My netro has been working fine for the past many months.
Suddenly it stopped working and light blinks.
I try to configure the Wifi again and it states
I am sure my 2.4 GHz network is available there as I have 2 other devices 10 Cm away from the netro and are working fine at 2.4GHz
I can confirm that in my Orbi Router.
Any ideas ?
Carlos
浏览: 3847   回复: 1
Link to smart light
Noam Leshem
更新时间 2020-05-16 17:53:06 UTC
浏览: 3677   回复: 1
EASTBOBDAM D
更新时间 2020-05-17 13:18:19 UTC
Thanks in advance
浏览: 3494   回复: 1
Yves Desrosiers
更新时间 2020-05-17 18:31:27 UTC
Thanks for your help :)
浏览: 3635   回复: 1
Watering program
Maciej Karpinski
更新时间 2020-05-18 01:01:57 UTC
浏览: 3713   回复: 1
Pixie sync Sprite
Sebastian Diaz
更新时间 2020-05-19 02:50:59 UTC
Thanks you Sebastian
浏览: 3986   回复: 1
