Battery status
Francis Ramos
更新时间 2020-07-07 15:07:47 UTC
浏览: 3296   回复: 1
Jim Falvey
更新时间 2020-07-07 23:54:23 UTC
浏览: 3605   回复: 1
Andrea Merito
更新时间 2020-07-08 07:15:38 UTC
thank you
Andrea
浏览: 3601   回复: 1
Arthur
更新时间 2020-07-08 16:08:19 UTC
浏览: 3307   回复: 1
JanT
更新时间 2020-07-08 18:44:04 UTC
浏览: 3409   回复: 1
Not enough watering time
Homestead One
更新时间 2020-07-08 20:04:00 UTC
I have 4 zones activated.
Please help.
浏览: 3604   回复: 1
Just stopped working?
Bari Sadler
更新时间 2020-07-10 21:41:47 UTC
浏览: 3142   回复: 1
Time delay
Bruce Vandyke
更新时间 2020-07-11 20:43:26 UTC
浏览: 3237   回复: 1
Scott McKay
更新时间 2020-07-11 21:50:21 UTC
浏览: 3146   回复: 1
Tariq Khan
更新时间 2020-07-11 22:25:30 UTC
浏览: 3398   回复: 1
Offline sratusc
Andrea Del Ben
更新时间 2020-07-12 19:31:12 UTC
浏览: 3548   回复: 1
Does Pixie timer have an integrated water back flow?
Sierra Kiner
更新时间 2020-07-13 17:27:01 UTC
Is water backflow integrated into the Pixie timer or does installation require a separate one?
浏览: 3564   回复: 1
user manual in spanish
Alejandro
更新时间 2020-07-14 10:00:20 UTC
浏览: 3543   回复: 1
Whisperer night light
Arthur
更新时间 2020-07-15 05:45:42 UTC
I have 2 whisperers. Both have the nightlight enabled to auto but only one of them turns it on at night the other never does. Any advice?
浏览: 3495   回复: 2
Smart watering issue?
Ananth
更新时间 2020-07-15 13:14:40 UTC
浏览: 3558   回复: 1
Netro Sprite dead after 27 months (3 months post-warranty)
Doug Burkott
更新时间 2020-07-17 11:26:34 UTC
Has anyone had an issue with their Sprite being inoperable shortly after the warranty ended?  I tested the power prongs with a voltmeter and the controller is getting electricity, but no lights are on.   It's 105 deg in Austin and no rain in sight.  I'm going out of town for 5 days, so I'm in trouble.  I'm going to have to go to Home Depot to get something off the shelf installed today before my trip.
Anyone with the same problem?  Has anyone been successful with a claim outside of the warranty period?
Update:  The Sprite went offline at the same time the LED light stopped working.  The watering schedule resumed two days later and the LED was still off.  Meaning - Sprite works fine, LED doesn't work.  Netro told me to send the unit in over the winter and they will repair the LED.  Awesome - thanks Netro!
All the best,
-Doug
浏览: 3756   回复: 2
Watering Frequency
Andrei Stancovici
更新时间 2020-07-16 05:36:44 UTC
Hello.
I installed my netro yesterday and now after watering all zones it shows me that the next watering will be in 5 days. It seems to be to far away in the future since it's 35 degrees celsius and sunny all day
浏览: 3319   回复: 1
Does Netro whisperer underestimate moisture?
Rick Agrawal
更新时间 2020-07-16 19:12:17 UTC
I added a whisperer to one of our zones. Recently the moisture content was between 25-30%. We are having a hot summer with many days with 110 degrees. I believed it and watered for good 15-20 minutes. It turned out despite all those water the soil moisture went up to 45-50%. I went and checked again, the soil looks pretty good and appeared moist.
Just curious if the whisperer tends to underestimate moisture?
浏览: 3458   回复: 1
I'm not understanding how "estimated frequency and duration" works...
Izio Sem
更新时间 2020-07-18 07:24:18 UTC
Ciao.
Just installed Netro Sprite.
I enjoyed to set up the zones with advanced Smart watering, but I'm not confident with what is reported in "estimated frequency and duration". The frequency showed in the setting page seems too long (e.g. every 6 days)... but, if I see what is scheduled in the calendar it seems much closer to my expectation (e.g. every 2 days).   How daoes it work??
Maurizio
浏览: 3650   回复: 1
Whisperer reset WIFI does not work
ozieaev
更新时间 2020-07-19 14:38:29 UTC
Got 2 Whisperer sensors recently. They came up not new (see some scratches on them and signs of use). As a part of install had to reset WIFI settings in order to connect to my WIFI. Pressing power shows red led. Issue is - pressing power 6 times (should switch to WIFI setup mode), does not work either. Still RED light.
Does anyone knows how to fix this?
浏览: 3561   回复: 4
