Problem With application
Alex Guerrero
更新时间 2020-10-17 08:21:08 UTC
浏览: 3327   回复: 1
Manually entering rainfall
Curt Lizzi
更新时间 2020-10-17 13:16:09 UTC
浏览: 3493   回复: 1
David Farries
更新时间 2020-10-24 20:24:40 UTC
浏览: 3533   回复: 1
Email address length
Alberto Castro Hinojosa
更新时间 2020-10-24 21:37:57 UTC
Could you review please?
浏览: 3426   回复: 1
Stefan Pena
更新时间 2020-10-25 10:41:41 UTC
Hey guys!
浏览: 3257   回复: 1
New user
Haris Eliades
更新时间 2020-10-28 20:35:38 UTC
Hello!
Zone 4, 2 minutes
Zone 5, 2 minutes
Zone 1, 4 minutes
Zone 2, 4 minutes
Zone 3, 4 minutes
Zone 4, 4 minutes
Zone 5, 2 minutes
浏览: 3298   回复: 1
How do I turn off for Winter?
Paul A
更新时间 2020-10-30 20:59:47 UTC
浏览: 3232   回复: 2
Add zones manually in queue
Haris Eliades
更新时间 2020-11-03 04:04:49 UTC
浏览: 3485   回复: 1
Didn’t water. Exclamation point inside of triangle
更新时间 2020-11-03 11:05:39 UTC
Controller didn’t turn on sprinklers at 0400hrs today.  Instead schedule shows yellow triangle with exclamation symbol, but gives no breakdown on why system didn’t turn on water.  If controller shows exclamation, it would be nice if it showed an actual description of problem/event.
浏览: 3783   回复: 1
dinzdale
更新时间 2020-11-03 16:00:28 UTC
浏览: 3362   回复: 1
Curt Lizzi
更新时间 2020-11-03 18:41:08 UTC
Am I doing something wrong?
Curt
浏览: 3563   回复: 1
Offline buy watered
Haris Eliades
更新时间 2020-11-09 06:22:11 UTC
浏览: 3410   回复: 1
Stan Balafas
更新时间 2020-11-16 17:52:28 UTC
Thank ypu
浏览: 3314   回复: 1
Jens Wymeersch
更新时间 2020-11-17 13:25:17 UTC
Dear,
Thank you so much,
Jens
浏览: 3882   回复: 2
App stuck on Idle
Pam Manwaring
更新时间 2020-11-18 02:21:16 UTC
浏览: 3195   回复: 1
Sensor and zone of control
Andrea Pieri
更新时间 2020-11-20 19:49:29 UTC
Dear support right now i am installing my new sensor connected with netro controller ( this is the first sensor) . I have 5 zone active but sensor is able to control just 3 zone is possibile to extend the sensor control  to a global of 5 zone for one sensor ? Thanks for your help .
浏览: 3482   回复: 1
Whisperer Battery
growerken
更新时间 2020-11-23 16:44:00 UTC
I have one whisperer,used in indoor garden.it looks like the solar is not enough for the charging.
Any idea I can fix it?
浏览: 3707   回复: 1
Haris Eliades
更新时间 2020-11-25 06:25:20 UTC
Haris
浏览: 3488   回复: 3
Master valve timing
joeac
更新时间 2020-12-04 05:38:31 UTC
Product: Sprite
Joe
浏览: 3385   回复: 1
How to make Netro sensor repair
Bowie Xu
更新时间 2020-12-06 21:04:42 UTC
My sensor doesn’t blink white led. When I presses the power button, it shows solid white for a while and then green color and red and goes off. The instructions make me confused. I tried to press the power button for 6 times. What does restart 3 times means? My sensor never goes to blinking white color.
浏览: 3794   回复: 1
