Battery dead
Arthur
更新时间 2020-12-07 22:00:27 UTC
浏览: 3463   回复: 1
Moisture uncorrect
Andrea Pieri
更新时间 2020-12-08 05:43:25 UTC
浏览: 4620   回复: 1
Automatic switch to 12 hour reporting for sensors
Julian Hansen
更新时间 2020-12-10 12:30:21 UTC
Hi I have 6 senors that have all worked perfectly for 3 months unattended. A month ago I noticed 1of them only had 5% charge so I switched it to 12 hour reporting and it is now on 38%. Today another sensor has gone to 0% charge and stopped reporting. It would be great if you could be set it automatically switch at say 30% charge. It will be 3 months before I am back to the house so I hope the sensor can recover. Thanks for a fantastic product.
浏览: 3621   回复: 1
Sensor Temperature Reporting
Nasser Ahmed
更新时间 2020-12-14 02:12:42 UTC
One of my sensors is reporting strange temperature numbers. Any ideas on how to fix this. I tried a reboot and a reset (remove and add again).
浏览: 3380   回复: 1
Pixie Valve Issue
Alec Simonson
更新时间 2020-12-15 05:48:10 UTC
Alec
浏览: 3733   回复: 2
Roman Stanek
更新时间 2020-12-27 18:34:40 UTC
浏览: 3065   回复: 1
Metro France cloud down?
Julian Hansen
更新时间 2020-12-29 01:07:40 UTC
浏览: 3551   回复: 1
Moisture and light range
Don Lewandowski
更新时间 2020-12-31 21:46:19 UTC
浏览: 4594   回复: 1
Darren Cassar
更新时间 2021-01-05 11:03:18 UTC
Darren
浏览: 3298   回复: 1
MAC address
John Conley
更新时间 2021-01-07 15:26:26 UTC
浏览: 3256   回复: 1
Technical question
Enrique Campos Sanchez
更新时间 2021-01-14 20:36:25 UTC
Hi team.
I would like to know what is the maximun wire longitude that support by zone the Netro Driver using 24 VAC power supply.
Thank´s.
浏览: 3431   回复: 1
Geron R
更新时间 2021-01-19 23:06:52 UTC
Please advise
浏览: 3310   回复: 1
Cancel
Awilda Betancourt
更新时间 2021-01-24 13:09:23 UTC
浏览: 3265   回复: 1
Date Format
Brian Keenan
更新时间 2021-01-29 09:00:07 UTC
浏览: 3168   回复: 1
Smart Watering Algorithm
更新时间 2021-02-09 13:52:56 UTC
浏览: 3665   回复: 1
Turning off
Rony Z
更新时间 2021-02-15 13:58:39 UTC
浏览: 3282   回复: 1
AMC
更新时间 2021-02-18 13:04:06 UTC
hello,
¿How Can I solve this issue?
APP version 2.5.3
浏览: 3298   回复: 2
Valve sttoped
Carlos Jimenez
更新时间 2021-02-18 21:28:28 UTC
Hi, I will apreciate if someone can help me, I'm going crazy, becouse suddenly, one of the solenoid valve stopped after 10 seconds. But the app show that it is running. I changed the valve with a new one, but same 7-8 seconds after run, it stoppes. Pls help me! Thanks
浏览: 3265   回复: 1
WiFi link
Benedetto
更新时间 2021-02-20 17:56:18 UTC
Hi, i would appreciate if someone could help me. I need to link the netro to the router without password, however the procedure need a password in any case: how can I do? Thanks for the support
浏览: 3079   回复: 1
explicit instructions on how to add weather station weather station, namely weatherunderground personal weather station
Joe Ryan
更新时间 2021-02-24 00:01:13 UTC
explicit instructions on how to add weather station weather station, namely weatherunderground personal weather station. How do you add station ID
浏览: 3422   回复: 1
