Zone not coming on
Herbert Bailey
更新时间 2020-06-15 13:00:35 UTC
浏览: 3312   回复: 1
Francis Ramos
更新时间 2020-06-15 15:03:45 UTC
浏览: 3286   回复: 1
Andy Black
更新时间 2020-06-15 21:10:38 UTC
Andy
浏览: 3268   回复: 1
Yard dying in Houston, TX
Daniel Alman
更新时间 2020-06-19 17:32:45 UTC
浏览: 3804   回复: 2
Certificate Expired?
Robohead
更新时间 2020-06-19 20:03:10 UTC
浏览: 3594   回复: 2
Programming square footage
Jeannaben Hyun
更新时间 2020-06-23 20:58:23 UTC
浏览: 3558   回复: 1
60 minutes maximum, problem
Brendan Burke
更新时间 2020-06-24 00:36:59 UTC
浏览: 3755   回复: 1
Rob and Susan Tartre
更新时间 2020-06-24 20:13:25 UTC
Thank you for any help!!
浏览: 4034   回复: 3
Igor
更新时间 2020-06-25 14:27:46 UTC
浏览: 3300   回复: 1
Power Cycle
Jorge Bastos
更新时间 2020-06-26 22:30:53 UTC
Any way to correct this?
Regards.
浏览: 3409   回复: 1
Text Colour un IOS App
Ignacio Sánchez
更新时间 2020-06-30 08:41:30 UTC
Any suggestion about ?
Thanks  in Advance.
浏览: 3272   回复: 2
Vision
Art Brownlee
更新时间 2020-07-02 01:24:34 UTC
浏览: 3121   回复: 1
low water pressure
vic sabo
更新时间 2020-07-02 22:08:39 UTC
浏览: 3488   回复: 1
Connessione wifi problematica
Emanuele Floridia
更新时间 2020-07-03 17:32:30 UTC
Buonasera a tutti,
C’è un rimedio?
浏览: 3258   回复: 0
更新时间 2020-07-04 13:11:16 UTC
Zone 1-11 minutes each run
Zone 2-11 minutes each run
Zone 3-06 minutes each run
Zone 7-06 minutes each run
浏览: 3571   回复: 1
Brendan Burke
更新时间 2020-07-04 14:38:40 UTC
浏览: 3576   回复: 1
Michael Fortwengler
更新时间 2020-07-04 19:06:14 UTC
浏览: 3347   回复: 1
sw238
更新时间 2020-07-05 15:42:38 UTC
浏览: 3388   回复: 1
Add solenoid valves
thái bình dương
更新时间 2020-07-06 17:01:57 UTC
hi netro
I have 48 solenoid valves and I want to connect 3 valves to 1 zone of the sprite kit, each valve has a capacity of 3w. Thank you
浏览: 3395   回复: 1
Hozelock
Alan George
更新时间 2020-07-06 18:50:08 UTC
浏览: 3393   回复: 1
