Sensor sending wrong data
Mick Faulks
Updated at 2022-01-14 06:49:41 UTC
Hi have my whisperer installed in a garden bed, it saying 0% moisture when the soil is quite wet and it is saying temp is 200 C up to 380 C I have reset it many times but continues to give these readings.
View: 8617   Answer: 1
Netro is watering at 25F because it is misinterpreted weather
Ben Aggus
Updated at 2022-01-11 12:15:06 UTC
I had to cancel watering because it’s 25F this morning. It’s because the weather is misinterpreted. The forecast today is 58/34, but that means it will be 34 for tonight’s low. Last night’s low was 25 and the Netro should look at that number for watering this morning.
View: 8855   Answer: 1
No wifi connection
lawnguy4
Updated at 2022-01-10 05:16:03 UTC
Just got the Sprite 6 controller and it won't connect to Wi-Fi. I have a mesh wi-fi system and the controller has full bars but it just refuses to connect. I reset it a couple times , I  unplugged and plugged it back in , I tried deleting the app and doing it again and still no luck. I just keep getting an error saying ''Action control parameter missing or value is empty'' no clue what that means. Can anyone give me some advice on what else I can possibly do to make this work.. Thank you.
View: 6562   Answer: 1
What is the expected format for entering weather underground? weather id?
August Divjak
Updated at 2022-01-07 23:41:01 UTC
For
KFLORLAN660 Id in weather underground app,. The setup continues to state that I should supply a valid I'd code.  I've tried many different ways with no luck.  Can you help here?
View: 7367   Answer: 1
i have problem with netro sprite 6
Nguyễn Vinh
Updated at 2022-01-06 04:51:41 UTC
I am a distributor of netro products in Vietnam market
My customer just sent back a product with a burnt electronic device inside (pictured). can you tell me what the possible reason is and how to fix it.
- 220V (stable) power supply
- no lightning or explosion
- Full safety equipment to protect electrical equipment when there is a problem.
Thank you very much
View: 8740   Answer: 1
Weather not updating
Mick Faulks
Updated at 2022-01-05 00:20:42 UTC
NetroWeather not updating, other weather apps only update if they are resubmitted every couple of days, is it possible to add other weather providers to the app?
View: 8644   Answer: 2
No restrictions set, yet program is skipping because of user restrictions
alan.ashby
Updated at 2022-01-02 11:40:53 UTC
I have no restrictions set, yet the app is indicating that restrictions are set and scheduled days are being skipped when they should not be.  Please see app screen shots.
View: 8117   Answer: 1
Jamie Campbell
Updated at 2021-12-29 10:45:55 UTC
Can you help?
View: 6833   Answer: 2
Master valve issue.
Danny L
Updated at 2021-12-29 04:13:11 UTC
View: 7685   Answer: 1
Whisper at 0%
Darren Cassar
Updated at 2021-12-27 09:00:28 UTC
View: 6702   Answer: 1
2 programs scheduled on one day
paul hewitt
Updated at 2021-12-24 05:21:45 UTC
I added an afternoon program after the morning one had run to run daily as very hot over next few days. After setting it up I went into schedule to make sure it was there and all that appears on the day is the morning schedule with a yellow triangle with exclamation mark instead of the usual tick to say it was done. I did see it running the morning schedule.
Why doesn't the afternoon schedule show up as well as the morning one?
Paul
View: 8505   Answer: 1
Manual recurring programs
Mark Johnston
Updated at 2021-12-23 23:56:32 UTC
Merry Xmas everyone
View: 6865   Answer: 1
Lyndon Whyatt
Updated at 2021-12-22 19:53:57 UTC
I reset my Whisperer sensor by following the reset instructions and on restart it flashed white. I added the sensor via the app but it didn’t produce a WiFi signal and I couldn’t connect to it in Settings on my iPhone. After a while it flashes dark blue.
What is happening and how can I fix it?
View: 8952   Answer: 1
davejburton@gmail.com
Updated at 2021-12-16 01:35:31 UTC
Howdy!
View: 8411   Answer: 1
Zone danssqm ?
SCAN Tektal
Updated at 2021-12-13 18:42:06 UTC
View: 7581   Answer: 3
Titousensei
Updated at 2021-12-12 22:51:43 UTC
View: 8130   Answer: 4
Login Error
alexepn
Updated at 2021-12-10 19:26:10 UTC
View: 6803   Answer: 1
Nguyễn Vinh
Updated at 2021-12-09 08:29:48 UTC
View: 7278   Answer: 1
Lawrence Mantin
Updated at 2021-12-05 17:01:06 UTC
View: 6686   Answer: 1
arubalsky
Updated at 2021-12-01 13:44:22 UTC
Example:
Pixie 1 - Nov 24 - Good run
Pixie 2 - Nov 24 - Good run
Pixie 2 - Nov 26 - Good run
Pixie 1 - Nov 28 - Good run
Pixie 2 - Nov 28 - Good run
Pixie 2 - Nov 30 - Good run
View: 8382   Answer: 1
