Smart Zone over watering
Scott Flanigan
Updated at 2022-03-26 11:21:58 UTC
View: 7105   Answer: 1
Werner Baier
Updated at 2022-03-26 09:58:21 UTC
View: 6894   Answer: 1
Sensores
Juan Pascual
Updated at 2022-03-23 21:35:24 UTC
Muchas gracias
View: 9032   Answer: 1
GERMONT Alain
Updated at 2022-03-23 10:10:18 UTC
Cordially
View: 9136   Answer: 1
Lloyd Walter
Updated at 2022-03-23 08:31:18 UTC
View: 13354   Comment: 3
Lose connection
Simone Teressi
Updated at 2022-03-21 23:28:54 UTC
I ve another problem...... If mybrouter connection goes down sprite begin to blink fast and when My router is on again Sprite do not automatically reconnect, i've to manually shut down and power in again Sprite.... Why?
View: 9569   Answer: 1
Updated at 2022-03-21 21:37:50 UTC
View: 8493   Answer: 1
metellusa@gmail.com
Updated at 2022-03-21 18:45:44 UTC
View: 9199   Answer: 1
Shkelqim Ismet Hoxha
Updated at 2022-03-21 14:10:28 UTC
View: 7185   Answer: 1
Lost connection
Simone Teressi
Updated at 2022-03-20 16:49:15 UTC
Router signal is 100%
View: 8407   Answer: 1
Hitesh
Updated at 2022-03-20 00:34:11 UTC
View: 7285   Answer: 2
Joe Baxter
Updated at 2022-03-18 22:42:37 UTC
View: 7091   Answer: 3
Mark Killeen
Updated at 2022-03-18 21:39:54 UTC
View: 7152   Answer: 1
Whisperers not sending data
Updated at 2022-03-18 12:17:29 UTC
View: 7374   Answer: 1
Justin Kirk
Updated at 2022-03-16 14:24:09 UTC
View: 6583   Answer: 2
Flow rate
Sander Z
Updated at 2022-03-14 12:34:05 UTC
View: 8096   Answer: 1
It says it sleeping
Judith Soth
Updated at 2022-03-12 22:25:49 UTC
View: 6916   Answer: 1
Problem Sprite 6
Davide Benfenati
Updated at 2022-03-12 16:41:44 UTC
View: 8061   Answer: 1
Netro pixie in standby
mbhi
Updated at 2022-03-12 10:44:15 UTC
View: 8168   Answer: 1
Whisper sensor
Anthony Bowersox
Updated at 2022-03-11 00:01:41 UTC
View: 6399   Answer: 1
