I have problem with netro pixie
Nguyễn Vinh
Updated at 2021-12-01 06:33:51 UTC
My Pixie can't enable manual mode, when i manually launch the app it says "Pending" and it doesn't work
View: 8519   Answer: 1
Vieri Verze
Updated at 2021-11-29 23:09:31 UTC
View: 6933   Answer: 1
Whisperer temperature and moisture readings are way off
Andrew
Updated at 2021-11-28 00:35:49 UTC
I recently bought a whisperer and for the first few days it worked perfectly but now it consistently reports the temperature as being over 300 degrees celcius, and soil moisture at 0% even while it has been raining here for a week.
I've tried relocating the whisperer and deleting and re-setting it up twice but get the same result.
I'm unsure what else to try. Does anyone have advice or a fix for issues like this?
View: 9633   Answer: 2
Mi experiencia con Netro
Marcelo Vasquez
Updated at 2021-11-25 18:21:23 UTC
Hola les cuento mi experiencia con Netro, trabajo actualmente en el estado de Nueva York, y tengo 500 plantas de bluebery en Chile souh America, y lo controlo desde acá, he tenido excelentes resultados con el sensor de humedad, me hubiese gustado que el sensor fuera más largo, pero con el actual se ha manejado perfecto, también creo que deberían diseñar una caja más robusta para exteriores, estoy muy feliz con la aplicación con el equipo y el sensor.
View: 12855   Comment: 2
Roger Prunonosa Duran
Updated at 2021-11-22 10:30:32 UTC
They haven’t lasted much…
View: 9435   Answer: 2
Whisperer failed?
Marlpit
Updated at 2021-11-15 21:27:46 UTC
View: 8937   Answer: 2
Rony
Rony Z
Updated at 2021-11-14 12:34:03 UTC
Do you have a phone number I can call you and talk to an agent?
View: 8799   Answer: 1
changelives
Updated at 2021-11-13 23:40:38 UTC
Did I set it up incorrectly?
View: 8384   Answer: 1
Blowout in the rain
lugo
Updated at 2021-11-12 19:02:41 UTC
View: 6362   Answer: 1
Erros
Nabil Ben ismail
Updated at 2021-11-10 13:50:29 UTC
Erreur 4847 ? C'est quoi
View: 6354   Answer: 1
Forecast not updating
Jacques
Updated at 2021-11-07 10:29:17 UTC
View: 8817   Answer: 1
How to do a manual zone start
Jim Smith
Updated at 2021-11-07 00:41:28 UTC
View: 7507   Answer: 1
Nuova interfaccia penosa!!
Andrea DiPi
Updated at 2021-11-05 03:00:01 UTC
View: 12999   Comment: 1
Home page
Updated at 2021-11-04 12:39:30 UTC
Nothing changed
View: 7386   Answer: 1
Multiple zones at once?
Lance Mace
Updated at 2021-11-03 20:03:29 UTC
View: 6768   Answer: 1
Greg Thomason
Updated at 2021-11-02 12:54:58 UTC
Hello.
View: 6660   Answer: 3
Updated app old problem
Szabi Hant
Updated at 2021-11-02 11:39:30 UTC
View: 7499   Answer: 3
Disconnect irrigation
Updated at 2021-11-02 10:24:53 UTC
View: 7226   Answer: 0
Battery Dead
Alan Stout
Updated at 2021-10-31 16:55:02 UTC
View: 6615   Answer: 2
Szabi Hant
Updated at 2021-10-23 04:46:29 UTC
Thanks in advance!
View: 7337   Answer: 1
