App crash
Jiang Zheyue
Updated at 2022-04-14 14:34:05 UTC
View: 6052   Answer: 1
Dsohunter
Updated at 2022-04-13 14:39:27 UTC
View: 7095   Answer: 2
Localization
JM del Amo
Updated at 2022-04-12 10:19:03 UTC
View: 7707   Answer: 1
Parts for Pixie
Robert Squires
Updated at 2022-04-11 14:11:50 UTC
View: 7005   Answer: 2
Like the app update.
Dave Henderson
Updated at 2022-04-09 02:14:47 UTC
View: 71441   Comment: 3
Mike Ahlmann
Updated at 2022-04-06 18:41:13 UTC
View: 6151   Answer: 1
Completely lost
jnk0
Updated at 2022-04-06 04:01:09 UTC
View: 5963   Answer: 1
Smaller time limits
Rocky Hill
Updated at 2022-04-05 23:28:18 UTC
View: 6210   Answer: 1
Maureen Horan
Updated at 2022-04-05 17:22:11 UTC
How do I add a zone
View: 5465   Answer: 1
manual app do not work
Updated at 2022-04-05 14:07:41 UTC
hi
no push button
View: 6088   Answer: 2
app / manual
Updated at 2022-04-05 14:03:37 UTC
View: 5986   Answer: 1
idpitt
Updated at 2022-04-03 14:58:04 UTC
View: 7714   Answer: 1
Pixie problem
Luis Borrás
Updated at 2022-04-03 10:22:59 UTC
View: 7038   Answer: 1
Dark Sky Weather
Martin K
Updated at 2022-04-01 19:51:52 UTC
View: 5882   Answer: 2
Addind new pixie
jesusvenegas
Updated at 2022-03-29 13:10:04 UTC
View: 5168   Answer: 1
Smart Zone over watering
Scott Flanigan
Updated at 2022-03-26 11:21:58 UTC
View: 5999   Answer: 1
Werner Baier
Updated at 2022-03-26 09:58:21 UTC
View: 5772   Answer: 1
Sensores
Juan Pascual
Updated at 2022-03-23 21:35:24 UTC
Muchas gracias
View: 7846   Answer: 1
GERMONT Alain
Updated at 2022-03-23 10:10:18 UTC
Cordially
View: 7970   Answer: 1
Lloyd Walter
Updated at 2022-03-23 08:31:18 UTC
View: 11805   Comment: 3
