Overriding smart waterinh
mvernia
Updated at 2019-03-17 20:46:27 UTC
View: 9431   Answer: 1
Scot and Michelle Cowan
Updated at 2019-03-03 17:04:51 UTC
View: 10777   Answer: 1
Nathan Anderson
Updated at 2019-02-13 03:53:31 UTC
View: 9990   Answer: 1
Tim Cox
Updated at 2019-02-02 01:35:59 UTC
View: 9891   Answer: 3
St. Augustine
Spencer Vaughn
Updated at 2019-01-10 03:15:53 UTC
View: 13011   Answer: 2
Leak detection
Joshua Berk
Updated at 2019-01-03 15:27:07 UTC
Rachio has a new leak detection device you can install on the pipe that talks to the controller letting it know if there's water flow that shouldn't be happening. Do you guys have plans to do anything like this? Would absolutely be interested in it!
View: 9777   Answer: 0
Sangjin Lee
Updated at 2018-12-15 18:56:48 UTC
Thanks in advance!
View: 15777   Answer: 1
Updated at 2018-12-13 07:48:53 UTC
Burning Bush
Fragrant Sumac
Japanese Yew
California Lilac
Creeping Juniper
Dwarf Forsythia
Snowberry
Siberian
Carpet Cypress
View: 14713   Comment: 1
Rebekah H
Updated at 2018-11-28 04:23:43 UTC
View: 9873   Answer: 1
Water pump shutting off
Ryan Cochran
Updated at 2018-11-26 02:32:24 UTC
View: 9931   Answer: 1
EPA rebate status?
Joshua Berk
Updated at 2018-11-04 07:39:58 UTC
Hi I was wondering if we could get an update on where Netro is with an EPA rebate? We're aware Netro has applied, but any word or ETA on getting certification for rebates?  Thank you
View: 10646   Answer: 3
Skipping skipped?
livingwater71
Updated at 2018-10-31 16:11:03 UTC
View: 9326   Answer: 1
Service
Matt Lasser
Updated at 2018-10-31 16:01:30 UTC
View: 9986   Answer: 1
George Zraick
Updated at 2018-10-27 20:05:15 UTC
View: 9727   Answer: 1
Moberley
moberleyj@verizon.net
Updated at 2018-10-17 16:59:29 UTC
View: 10185   Answer: 1
connecting to wifi..
Phani Gade
Updated at 2018-10-15 17:20:42 UTC
View: 9316   Answer: 0
Customization->set rain/temperature/wind threshold to skip watering
Updated at 2018-10-13 06:19:08 UTC
Netro automatically creates dynamic watering schedules according to local weather, so if you turn on the smart zone feature for your zone, season adjustment will be made with smart watering schedules according to weather.
There are different types of weather restrictions: rain, temperature and wind.
By default, If you turn on the smart zone feature, Netro will skip the schedules (including manual schedules from user programs) when there is a chance of significant rain(>0.2inch).
The default threshold to skip watering when temperature is too low is 0 Celsius degree (32 Fahrenheit) for all the Netro controllers.
You can now customize rain, temperature and wind threshold through Settings->Preferences.
View: 13299   Comment: 0
Controller
Phil Samson
Updated at 2018-10-12 18:41:33 UTC
My controller shows that it’s online but the app is saying I’m offline. How do I correct this?
View: 9436   Answer: 0
Joshua Berk
Updated at 2018-10-10 06:22:09 UTC
View: 10367   Answer: 3
New seeding
Douglas Ely
Updated at 2018-10-09 23:09:48 UTC
Here in ocean city NJ, when we seed for new grass we need the water to come on twice daily to start germination. When I set my Netro to “new plant” and the soil type to “sandy clay” which is the top layer, the controller had only been watering every 2.21 days. The soil is dust dry. I don’t want to have to make gross adjustments. That is why I bought Netro. What’s wrong?
View: 11722   Answer: 3
