Whisperer Changing Colors
Patrick
Actualizado 2020-05-06 02:32:37 UTC
My Netro Whisperer sensor LED changed colors from blue to red on its own.  Is this normal?
Ver: 7313   Respuesta: 1
Sprite app says its watering but it is not
Jen Morgan
Actualizado 2020-05-03 18:02:31 UTC
It has been working for 3 weeks, but now it does not.
I have checked all 7 zones. No wiring issues. Has proper voltage.
It just won't come on. How do I get it to work again. This is a new unit. Sprinklers are all fine and had a tune up when the Sprite was installed.
I have unplugged it and plugged it back in. I need help soon, I have new sod and many new plants in my yard and gardens.
Ver: 7439   Respuesta: 1
Sprinklers don’t work
Richard Mundy
Actualizado 2020-05-02 18:59:26 UTC
Please help
Ver: 7907   Respuesta: 1
Carlo Monico
Actualizado 2020-04-26 06:59:36 UTC
Grazie.
Ver: 7211   Respuesta: 1
Plant Sensor
Ntenaive
Actualizado 2020-04-25 21:56:51 UTC
Ver: 7974   Respuesta: 2
Gian Piero Pepino
Actualizado 2020-04-25 09:23:06 UTC
Gian Piero
Ver: 7372   Respuesta: 1
Best sync option?
jbart65
Actualizado 2020-04-22 02:56:17 UTC
Ver: 7559   Respuesta: 1
google home not connected
maxtrash
Actualizado 2020-04-21 23:01:57 UTC
what could be going on?
Ver: 7288   Respuesta: 2
Keep Connected option
jbart65
Actualizado 2020-04-17 17:38:10 UTC
The particulars:
Ver: 7554   Respuesta: 1
Which Alexa app?
jbart65
Actualizado 2020-04-16 20:00:55 UTC
Jeffry
Ver: 7671   Respuesta: 1
Netro app on google home
Danilo
Actualizado 2020-04-11 10:07:58 UTC
Thanks for your support.
Ver: 7430   Respuesta: 1
Settings
Massimo Povolo
Actualizado 2020-04-07 06:31:48 UTC
Ver: 8436   Respuesta: 5
Home Assistant integration
Casey S
Actualizado 2020-04-05 19:46:53 UTC
Ver: 8151   Respuesta: 2
duerson
Actualizado 2020-03-27 20:59:20 UTC
Ver: 7752   Respuesta: 1
Delivering term please
yodiego
Actualizado 2020-03-14 18:08:21 UTC
Ver: 7183   Respuesta: 1
alexa & pixie
stefano banfi gaslini
Actualizado 2020-03-11 14:30:37 UTC
hi,
TNKS
best regards
stefano
Ver: 7539   Respuesta: 1
Actualizado 2020-02-28 07:49:20 UTC
Ver: 11970   Comentario: 3
Changing ownership of home
Dario Sindicich
Actualizado 2020-02-14 01:48:40 UTC
Ver: 9136   Respuesta: 2
Robert Bayes
Actualizado 2020-02-07 03:39:19 UTC
Ver: 7083   Respuesta: 1
Introducing the Referral Program
Actualizado 2019-12-10 03:02:22 UTC
To the Netro community:
We are pleased to launch the Netro Referral Program. You can earn reward points when your friends become Netro customers!
1.Invite your friends to join Netro using your unique link
2.Your friends get a discount or reward points
Your friends enjoy 10% off their first orders or $10 credits toward their first subscriptions.
3.Get your reward points and repeat to earn more
You will earn reward points* equivalent in value to the discounts or credits given to your friends.
*Reward points: for every US dollar your friends spend on their first orders you will earn 10 points ($0.1). You will earn 1000 points ($10) for every friend who chooses to subscribe. There are 3 ways to redeem the reward points:
1. Use the reward points to purchase Netro products at netrohome.com (100 points = 1 US dollar)
2. Use the reward points to pay for your subscription fee at netrohome.com (100 points = 1 US dollar)
3. Withdraw the reward points to your PayPal account (200 points = 1 US dollar)
Your reward points will never expire.
You can check more info about Netro's Referral Program here https://netrohome.com/shop/refer
Ver: 9023   Respuesta: 2
