How do I save my password
Ruth Wengert
Actualizado 2026-06-09 16:33:16 UTC
I doubt if someone’s gonna break in and change my sprinkler time how in the hell do I save my password to this thing? I don’t wanna have to remember to put it in every time I want to change my sprinklers.
Ver: 2223   Respuesta: 1
Change Wi-Fi connection
Ruth Wengert
Actualizado 2026-05-20 03:18:14 UTC
I have changed the name of my Wi-Fi. I need to change my Wi-Fi connection to its new name
Ver: 2152   Respuesta: 1
Changing WiFi Network post original installation
deleted_20260518221841_george
Actualizado 2026-05-18 14:03:27 UTC
Hi- been using your sprinkler controller for several years and have recently added a new WiFi network.
I'm following the instructions how to switch the Netro controller to a new WiFi network. After resetting the controller, it change my iphone WiFi network over to Netro-XXX (which tells me I have no internet access).
When I return to the Netro app and click 'Next', it just keeps instructing me to connect to Netro-XXX first.
The Netro controller continues to blink despite unplugging it so stuck in limbo now.
Ver: 2220   Respuesta: 2
Why would it show rain on the Home Screen when there is none in the forecast
Michael Harrington
Actualizado 2026-05-16 01:39:35 UTC
Ver: 2258   Respuesta: 1
When Zone 11 is programmed to run but zone 4 runs instead.
Mike
Actualizado 2026-04-21 18:10:56 UTC
Zone 4 correctly runs when zone 4 is activated
Ver: 2921   Respuesta: 1
Any way for user to open and replace battery in Whisperer 2?
Actualizado 2026-04-09 02:24:02 UTC
Any way for end user to open and replace battery on a whisperer 2?  It is out of warranty.
Ver: 3074   Respuesta: 1
Peter OBRIEN
Actualizado 2026-03-27 00:55:46 UTC
Samsung S25 - unable to pair own WIFI after connection to Netro
Ver: 3492   Comentario: 1
Pixie solar panel
Noam Leshem
Actualizado 2026-03-23 14:31:41 UTC
Just i thought. My pixie is connected to a tap that is shaded most of the day. It would be great if the solar panel was removable so it can be placed in a better place with a wire to the pixie.
Ver: 3364   Comentario: 2
Pixie se desconecta
Lino
Actualizado 2026-03-22 19:30:16 UTC
Por qué se desconecta después de unos minutos mi unidad Pixie si tiene batería?
Ver: 3125   Respuesta: 1
Drip
Tim P
Actualizado 2026-03-22 18:23:10 UTC
All the zones work except I do not have any water coming out of the drip heads
Ver: 3019   Respuesta: 1
Drip
Tim P
Actualizado 2026-03-22 18:03:51 UTC
Ver: 3043   Respuesta: 1
Drip
Tim P
Actualizado 2026-03-22 18:03:43 UTC
Ver: 3035   Respuesta: 1
New whisperer
Actualizado 2026-03-03 08:20:29 UTC
Bought a new whisperer as an old one is no longer working.
REMARK : WHILE I LIVE IN A TEMPERATE AREA NONE OF MY WHISPERERS LASTS MORE THAN 26 MONTHS WHICH IS SURPRISING AS IT IS NOT SUPPOSED TO BE A CONSUMABLE.
Clicked as required first blinking blue light then blinking white light.
Went to sensors and see the dead old one, the working one but do not see the newly bought one.
Do not see either a + sign to add a new one.
What should I do ?
Ver: 3321   Respuesta: 1
Tuan Phan
Actualizado 2026-01-25 18:28:34 UTC
Ver: 3227   Respuesta: 1
Eric Jonsson
Actualizado 2026-01-08 12:02:58 UTC
Ver: 3608   Respuesta: 1
API broken?
Tortfeaser
Actualizado 2025-11-21 04:58:13 UTC
Hi, I can get my Netro controller info using:
curl -v https://api.netrohome.com/npa/v2/info.json?key=MYAPIKEY
(where MYAPIKEY is a key from the user account page)
but when I try to update soil moisture data with:
curl -X POST -H "Accept: application/json" -H 'Content-Type:application/json' -d '{"key":"MYAPIKEY","moisture":100}' "https://api.netrohome.com/npa/v2/set_moisture.json"
I get an error about an invalid key:
{"status":"ERROR","meta":{"time":"2025-11-21T04:54:56","tid":"1763700896_KpmY","version":"2.0","token_limit":0,"token_remaining":0,"last_active":"2025-11-21T04:54:56","token_reset":"2025-11-22T00:00:00"},"errors":[{"code":1,"message":"Invalid key: ","params":{}}]}
What's going on?
Ver: 15979   Respuesta: 1
Zone flexibility
Mike R
Actualizado 2025-10-29 01:20:50 UTC
I have a hill that was terraced and replanted. I was told to run the circuit twice a day for 15 minutes for a month. Drip lines. Seems like my system doesn’t have that flexibility. Am i correct?
Ver: 4042   Respuesta: 1
App crash
Nick
Actualizado 2025-10-12 20:41:50 UTC
The app crashea when I click on a zone on Google pixel 8a. I had to configure them with another phone. Already tried to reinstall the app and clear cache
Ver: 4319   Respuesta: 1
L irrigazione non parte
Marco Michelini
Actualizado 2025-10-11 15:55:45 UTC
Hi, dopo aver collegato tutto, ho provato a fare un test manuale ma non parte l irrigazione.
Sapete aiutarmi?
Ver: 4119   Respuesta: 1
Program change Day
Tiziano Pacella
Actualizado 2025-09-17 19:04:30 UTC
Someone can help me?I need change the day for one program exists...what is the procedure? Thak you
Ver: 5247   Respuesta: 1
