API key
Actualizado 2026-10-17 14:55:20 UTC
where can i find my unique API key for my controller? i'm trying to set up automation. I'm looking for a 40+ character alphanumeric string generated from my registered Netro account.
Ver: 648   Respuesta: 0
Steve Mayes
Actualizado 2026-10-05 11:17:22 UTC
System goes off line every other day at about 2:30 am. I simply unplug and plug it back.
Ver: 638   Respuesta: 0
EPA watering
Actualizado 2026-09-30 10:51:59 UTC
I want to save water in the long term , what is the best watering EPA or Deep. I want to set it up now the temperature has lowered and I want to boost the roots
Ver: 700   Respuesta: 0
App keeps requiring password reset
Rockhead413
Actualizado 2026-09-18 23:02:56 UTC
  • App keeps requiring password
Ver: 965   Respuesta: 1
John Jessee
Actualizado 2026-09-18 18:53:08 UTC
Just read about this new app.  It shows exaclty how kuch rain fell on an exact location.  Not rehional or local weather station.  Can this link to this app to turn off watering when it rains
Ver: 946   Respuesta: 1
Mike Carey
Actualizado 2026-09-04 14:18:00 UTC
Ver: 1233   Respuesta: 2
Joel Braunstein
Actualizado 2026-08-14 20:04:32 UTC
Ver: 1445   Respuesta: 1
Valves Not Opening
Micky Boles
Actualizado 2026-08-09 21:16:47 UTC
Netro controller has run fine for 3 or 4 years. Trouble arose overnight. Controller is connected to my WiFi and no lights blinking,  it if I do, say, a manual run, it sends the command to the controller, and the app thinks it is running water, but the valves aren't opening. Have tried to do this with multiple valves, have reconnected to WiFi, etc but can't make it open valves. Ideas?
Ver: 1568   Respuesta: 1
Candice Wang
Actualizado 2026-08-06 07:50:00 UTC
Dear Netro Community,
What We Are Doing
📧 support@netrohome.com
Best regards,
Netro Support Team
Ver: 9282   Comentario: 0
Pixie
Magnus Swenson
Actualizado 2026-07-12 18:45:13 UTC
Can you add external choice vs plants ; this device can actually have multiple use like pool filler timer etc thank you ! Pixie 1 solar hose timer
Ver: 1815   Respuesta: 2
Using Netro Watering on Polyglot 3x
Peter Henneberry
Actualizado 2026-07-12 17:13:10 UTC
Anyone using the universal devices polyglot plugin for Netro version 0.1.18
In the configuration it states to use my serial number from the Netro Spark which I see on the Netro app but when I add it and click save, Polyglot says it is an invalid serial number
Ver: 1718   Respuesta: 0
Wrong location detected: Italy address is always converted to Oklahoma, USA
tizzy
Actualizado 2026-07-02 10:11:39 UTC
I have a Netro Spark 8 controller installed in Italy.
My address is:
Via Gonfalone 49
73031 Alessano (LE)
Italy
However, Netro always changes my location to:
  • ZIP code: 73032
  • State: OK
  • Country: United States
Because of this, the weather forecast is completely wrong and Smart Watering is using incorrect weather data.
I cannot edit the ZIP code, state or country, either in the Android app or on the web interface.
Could you please help me fix my location or update your geolocation database?
Ver: 1880   Respuesta: 1
No water coming from sprinklers of 3 zones
Sukesh Arora
Actualizado 2026-06-28 15:31:51 UTC
Although the App says that it is watering a particular zone but no water comes out of the sprinkler heads. What could be causing that?
Ver: 1921   Respuesta: 1
Sukesh Arora
Actualizado 2026-06-28 15:23:05 UTC
Ver: 1866   Respuesta: 1
Netro Skill
ghutch2262
Actualizado 2026-06-26 14:52:07 UTC
The netro skill does not stay connected to Alexa.  What is the issue with that?
Ver: 2003   Respuesta: 1
Nuovo wi fi e luce spenta
Paolo Grippa
Actualizado 2026-06-21 08:13:39 UTC
A seguito di nuova installazione wi fi fibra home, il dispositivo mi da luce spenta come se non arrivasse corrente, ma in realtà la corrente arriva. Ho infatti provato a staccare e riattaccare tutto ma la situazione non cambia. Quale può essere il problema?
Ver: 1944   Respuesta: 1
Es un problema
Alejandro Miguel
Actualizado 2026-06-17 20:34:07 UTC
El programador es un verdadero rollo deja de tener conexión no actúa riega cuando le da la gana no lo recomendaría jamas
Ver: 2618   Comentario: 1
Più elettro valvole
Enrico Crola
Actualizado 2026-06-11 08:07:24 UTC
Come faccio per poter attivare in una zona più elettrovalvola contemporaneamente??
Ver: 2026   Respuesta: 1
Anne M
Actualizado 2026-06-10 22:39:31 UTC
For test purposes, I have my Whisperer 2 in a terra cotta flowerpot that is very dry.  It always reads that the moisture is very high.  I have a Pixie at the house faucet.  I reset the Whisperer and it did not help.  What's wrong?
Ver: 2041   Respuesta: 1
Cannot connect to my WiFi
Actualizado 2026-06-10 02:59:45 UTC
Tried several times following with the instructions. And failed!? And my system was operational and my App was disabled for no apparent reasons!?
Ver: 2001   Respuesta: 2
