Scheduled Runs not turning on but app shows they ran
Dakota Haeffner
Actualizado 2021-05-02 17:04:53 UTC
My app is showing scheduled runs for morning and nights that I set up using a repeating program. At the time they are supposed to run they just saying loading the entire time. After they don’t run I can do a manual run through the app and it works fine. Any suggestions?
Ver: 3851   Respuesta: 1
Internet connection
Sheryl New
Actualizado 2021-05-02 21:57:36 UTC
My Netro Sprite constantly drops offline. Help, please.
Ver: 4016   Respuesta: 2
Latest software update
Sheryl New
Actualizado 2021-05-02 21:59:11 UTC
Is 2.5.3 the latest Netro Sprite software version?
Ver: 5439   Respuesta: 3
Whisperer in the UK
Marlpit
Actualizado 2021-05-02 23:16:04 UTC
Really liking the Netro Pixie, keen to pick up the whisperer. How do i get one in the UK. Shipping from the states is expensive?
Will the Pixie work with the Whisperer without needing a bridge?
Ver: 4119   Respuesta: 1
Whisperer shows different data on hourly vs daily humidity
Panos Charalambopoulos
Actualizado 2021-05-03 07:40:53 UTC
My whisperer shows 99% humidity stuck in one zone in the hourly and dashboard views. The weekly daily monthly views all show progressively dropping humidity. Which one is correct and how do I possibly reset this ? Also do my watering schedules get affected by the hourly or the daily humidity ?  My other whisperer shows consistent data between hourly and other views.
Ver: 3921   Respuesta: 1
Just checking
Momma & Papa Behr
Actualizado 2021-05-03 12:53:18 UTC
I wondered if there are any Metro Omaha Landscaping Companies on this forum.
Ver: 3902   Respuesta: 0
Whisper
Richard Mundy
Actualizado 2021-05-04 18:07:58 UTC
I have recently bought  a whisper to complement my Netro watering system. It was bought from Amazon, but showed  no signs of life after following the instructions. I have left in the garden presuming it was flat. After a few day the unit is still showing a red light suggesting the battery is still not charged . Is the unit faulty?
Ver: 4355   Respuesta: 1
Whats the difference between Forecast and Expectation
Julio Perez
Actualizado 2021-05-09 16:43:52 UTC
I was looking on the preference section and see that we can select one of this. By default come with expectation selected. Wich is better?
Ver: 3771   Respuesta: 1
Update Firmware
Tognaz
Actualizado 2021-05-10 12:35:23 UTC
Hello everyone,
Checking with the Netro app, I see that my Sprite has firmware version 2.2.0, while I think I read in the forum that there is version 2.5.3.
How can I force the update?
Ver: 4047   Respuesta: 1
Pixie displays Soil Moisture reading without any sensor
Michael Host
Actualizado 2021-05-11 03:07:21 UTC
Hi.  My Pixie shows a Soil Moisture reading that changes over time, but it doesn’t have a Whisperer connected to it.  It seems to influence the watering frequency.  When I look at the watering schedule, it’s supposed to water every nine days, but instead it’s watering every three days.  Is this normal?
Ver: 3914   Respuesta: 1
Where do I have to install the whisper sensor?
Paolo1968
Actualizado 2021-05-11 09:46:31 UTC
I have recently bought  a whisper sensor to complement my Netro watering system. I have a watering system in the garden, where Can I install the whisper in order to avoid it will be wet all days by the watering system? Do I have to put it outside of the garden? Thanks. Paul
Ver: 4575   Respuesta: 2
Whisperer stop working
Gianluca De Virgilio
Actualizado 2021-05-11 15:34:15 UTC
Ideas?
Ver: 4122   Respuesta: 1
Smart water regulation
Albert Heinold
Actualizado 2021-05-13 09:40:49 UTC
Thanks for any help.
Ver: 3780   Respuesta: 1
Whisper Pairing
Sang Peiris
Actualizado 2021-05-13 12:11:59 UTC
Hello-  I have two new whisper devices. Both will not go into pairing mode.  Press power button six times and the light just blinks red on and quickly off. Press three times and same thing.
How do I get the whisper into pairing mode?
Ver: 4255   Respuesta: 1
Rainfall from weather station
Actualizado 2021-05-14 16:50:13 UTC
Ver: 4187   Respuesta: 1
John Lillistone
Actualizado 2021-05-15 09:23:08 UTC
Any ideas anyone?
Ver: 3960   Respuesta: 2
Watarering modes
Actualizado 2021-05-16 07:44:57 UTC
Hi there
Ver: 4477   Respuesta: 2
Seed watering
Adrian Azzopardi
Actualizado 2021-05-16 10:18:05 UTC
Ver: 3925   Respuesta: 1
Turning off wayer
Actualizado 2021-05-16 21:29:12 UTC
Ver: 4287   Respuesta: 2
Programs Setup
fernando colon
Actualizado 2021-05-18 04:44:56 UTC
I have 5 zones programmed daily in 15/20/35 mins intervals however when I goto the home screen I see them all in 15mins intervals... Seems as the home screen bypass' the current daily programmed schedule.  How do I have my programs run as intended 15/20/35 .ins intervals vs the 15mins it self imposed?
Ver: 4383   Respuesta: 1
