Michael Sheahan
Actualizado 2021-04-19 21:19:54 UTC
Ver: 3969   Respuesta: 1
Mitch Green
Actualizado 2021-04-20 00:44:59 UTC
Ver: 4489   Respuesta: 1
Jason
Actualizado 2021-04-20 21:49:32 UTC
Ver: 3779   Respuesta: 1
Weather data
Vardhan Rajkumar
Actualizado 2021-04-21 18:03:34 UTC
Vardhan
Ver: 4300   Respuesta: 1
Zones
dougbrandes
Actualizado 2021-04-22 12:34:57 UTC
I only have 2 zones.  1st zone is programmed for only 2 days per week while the 2nd zone is programmed everyday and at a different time then the first zone.  However on the 2 days the first zone comes on, the second zone does not despite be programmed to.  As mentioned the on times are completely different.
Ver: 3793   Respuesta: 1
Trigger a single zone based on zwave switch
Moe E
Actualizado 2021-04-22 14:54:46 UTC
My pools water fill line is connected as a zone on my sprinkler system. I would like to trigger turning on and off a zone based on a zwave switch status. Can this be done, or should I return my netro for a different system? It looks like netro does not have api access, and IFTTT is extremely limited. Thanks
Ver: 3993   Respuesta: 1
LAWN
Actualizado 2021-04-23 23:08:09 UTC
Set up wifi
Neti URC - 87B (ok saved)
home netwok connected.
Ver: 3999   Respuesta: 1
Open tel zones atbthe same time
ivan hernandez
Actualizado 2021-04-25 11:58:25 UTC
I have to activate two zones at the same time but i dont know how to do It.
Ver: 3878   Respuesta: 1
Can not connect to wifi
Andrei Stancovici
Actualizado 2021-04-25 18:30:25 UTC
Hello. I have restarted my netro 16 after winter. First it connected ok and after a power lose i stopped connecting to wifi. I have tried everything. The light is solid as if is connected. Plese help. Thank you
Ver: 3727   Respuesta: 1
Netro app discover tab
Zee D
Actualizado 2021-04-25 20:52:09 UTC
Ver: 3837   Respuesta: 1
Run Off Adjustment?
Carey Family
Actualizado 2021-04-26 03:28:07 UTC
Hi Netro, I have fruit trees in clays soils and I have the whisper sensor helping me monitor the water. I have two issues right now. One is the sensor does not seem to detach much change in the moisture content in the soil, even immediately after an hour of watering. The other issue is I am getting run off during each watering cycle but I cant figure out how to spread out the watering or reduce them without going to a manual setting. Can you help me? Thank you!
Ver: 4150   Respuesta: 1
I live in the US but want my temperature in celsius
smartplastic
Actualizado 2021-04-27 00:19:53 UTC
Hi I’m and Aussie living in the US and although I am happy to use pounds and feet etc Fahrenheit is just a ridiculous pile of crap that is used nowhere else in the world.
How can I get the temperature display in my Netro app to show in Celsius?
Ver: 3841   Respuesta: 1
Cycle And Soak?
Actualizado 2021-04-27 02:42:48 UTC
Is their a cycle and soak setting that can be chosen on the spark controller?  Several smart controllers on the market offer the setting.
Ver: 4309   Respuesta: 1
Whisper controlled zone down to 11%
Simon Clark
Actualizado 2021-04-28 20:59:55 UTC
I have a whisper connected to a zone that I have defined as new plant as it’s young vegetable plants. It says it will run every day for 9 minutes.
However it’s not come on for the last week and when I checked today the moisture was down to 11%!
Why hasn’t the zone been running?
I can’t rely on your product if it doesn’t do the basics that keeps my plants alive.
Ver: 4285   Respuesta: 1
How to tell common wire
Shai Amiel
Actualizado 2021-04-30 15:27:16 UTC
I had dc solonoids so Im redoing the whole system.
I boyght bermad 24vac solonoids, they have 2 wires but both are red - how do I tell which one is connected to the common spark plug.
Shai
Ver: 4038   Respuesta: 1
Adjusting watering amount to match restrictions
Trevor M
Actualizado 2021-05-01 11:37:20 UTC
My region is currently asking that we only water once per week. I was under the impression that the smart controller made those adjustments automatically for me, but it is showing that I am scheduled to water 3x this week. Is the only way for me to change this to do it manually?
Ver: 4311   Respuesta: 2
Any promotion codes/discounts available?
Actualizado 2021-05-01 18:03:02 UTC
Looking to purchase a couple of whisperer sensors, and can’t really justify the $60 price.  Any discount codes/discount for multiples available?  Any money back guarantee if not satisfied with the whisperer?
Also,  how many people are using advanced smart water feature that allow the controller totally decide when to water.  I have set it up but cringe at the runtimes and days running in the calendar, and keep reverting back to my schedule.  Seems like it would be using a lot more water.
Ver: 4278   Respuesta: 1
To many watering with smart option
Adrian Nagy
Actualizado 2021-05-02 06:10:18 UTC
Dear Netro,
I jut set up your device (again; because it is spring here); but smart watering time look way to much. Why do I need to water my 100 Sqm grass 5 times 8min in a day?
Thank you for your help in advance , Adrián
Ver: 3990   Respuesta: 2
One of my zones isn't smart watering
Mitch Green
Actualizado 2021-05-02 12:39:44 UTC
2 of my 3 zones are automatically watering however one zone is not any thoughts why?
Ver: 4246   Respuesta: 1
soil fertility
Actualizado 2021-05-02 15:17:33 UTC
Why the Whisperer doesn’t measure the soil fertility?
Ver: 4117   Respuesta: 1
